Help! Faito s4 evo valve clearance on stock bore
CLYDE
First time for my mechanic to install racing camshaft this coming saturday, what is the recommended valve clearance for faito s4 evo cam? performance setting? fuel efficiency setting? and safety setting - im just afraid that the valves might hit the piston during high rpm because of additional lift. Im already using vixion valve spring and brt cdi.:)
4f7erx
First time for my mechanic to install racing camshaft, what is the valve clearance for faito s4 evo cam? performance setting? fuel efficiency setting? and safety setting - im just afraid that the valves might hit the piston during high rpm because of additional lift. Im already using vixion valve spring and brt cdi.:)
bro. just asking of your newly installed faito s4 evo, is it plug in play ? hows the performance?
6sic6
intake .08mm
exhaust .09mm
expect mo na yung lagitik pero tolerable yan naka cams ka na eh...
CLYDE
intake .08mm
exhaust .09mm
ganun ba pafs lau pla sa stock setting, d pla totoo na plug and play, stock kc minimum eh .10 in .16 out, tnx
CLYDE
Safe pa rin ba .o8 in at .09 out sa long rides at babaran?, para lang kc masyado tight setting bro
emcid_ubp
kami s4 evo cam at cms valve spring naka 60mm bore na faito din ang intake valve clearance na ginawa namin ay 10 ang exhaust ay 15. mababa lang ang s4 evo kaya wag ka magalala sa lagitik di masyado maingay yan.
