Help - Fuel Gauge Problem
guitarizta
Hi, this morning i ran out of gas without me knowing it, as my fuel gauge is not working it is stuck in the middle of F and E in the indicator.
Q: What is the common cause of this so that I can check it?
guitarizta
it is located at the tank check the connector in the floater clean it if its needed to
Done checking everything sir, I even did the troubleshooting guide in the service manual everything is within specification except the floater inside the tank.
I move the floater in up position for about 5 minutes i hold it in that position the fuel level gauge in the panel should react and go to F but did not and vice versa.
The suggestion of sir buster about the resistor i did not yet check.
If my fuel sender unit assy is defective, will the part of yamaha mio will do for replacement?
john_carlo
are you referring in the flaoter if so as far as i can see in my mio and sniper the floater is the same
guitarizta
yes i'm referring to the floater inside the tank together with the electrical part, i'll try to borrow from my friend for troubleshooting...thanks
Update on my problem: Admin traxx is 101% right! Apparently the one of the resistor on the odometer is disconnected/cut so I re-solder it to place and finally my fuel gauge is functioning. Thanks to all of your replies...
in few months time same problem will appear...
your always in full tank?
