Gear Position Sensor Output Voltage are inputted through the CDI Unit and the installed Micro-processor(inside the cdi) decides on the most suitable ignition time according to the rotation of the engine by calculation and simultaneously outputs the primary voltage of the Ignition Coil regularly in times when the battery voltage changes giving safe ignition output .
My observation as to why the "pink" wire is connected to 2nd gear only:
Yamaha T135 is designed to have quick response/acceleration compared
with other cubs/underbone bikes.
when in city traffic, first gear and second gear are the ones mostly used.
(yamaha always states that t135 can overtake vehicles "very quick" from a traffic stop)
Why second gear?
because first gear dont need special extra acceleration power because
being low gear has the power already.
Second gear is most suited because this is used to overtake vehicles
from traffic light stop to Go.
Why not 3rd or fourth gear?
the third and fourth gear are already for high speeds and it doesnt
need quick acceleration.
Now, those are just my observation
trieunt said:
Maybe, but I am considering about the TPS and thermo sensor . What are their function participating in CDI ?
I think they are present in wiring diagram with the protect engine overload at too high of beat and heat.
If I remove the TPS out of function on wiring diagram, what 's matter ? Better or problem ?
TPS will determine if position of your throttle if its 1/4 or 1/2 or Fully open.
based on that, the "microprocessor" inside the CDI will know what to do best with the motorcycle. either it will give more acceleration or not.
It is not advisable to get rid of the TPS, From what i read,
not using/connecting the TPS will provide less power.
see the third graph here
http://www.svrider.com/articles/2001jul_carbs.htm
