Help Mga Master!
ONE3FIVE
Mga master tumirik kanina motmot ko, akala ko lunod lang pero may langis sa SP at ayaw na talaga mag start ano po kaya prob.? Help po
Paladin
When you kick start, does it have compression? If no, you have a blown out engine since you said you have oil on SP.
ONE3FIVE
Bago po sp ko sir, pero bago ako mag palit lage nalulunod sp ko, kaya nag palit po ako ng bago, sabe po ng tropa ko baka sa valve seal or sa mismong valve daw? Ganun po ba pag palitin na valve seal?
Paladin
Have you tried to use a new SP after your MS stopped running? Sp can get busted even if it's new. BTW, what happened before it stopped starting?
ONE3FIVE
I still haven't tried new sp, before it stopped running sir, I used it from north cal. To manila back n forth tapos north cal to 10th ave, naka uwe pa po ako nun tapos nung bumile ako jan sa malapit pinatay ko makina tas nung inisstart ko umadar lang saglet, wala padin ung mekaniko nagumawa ng mc ko amp useless mc ko ngayon, nung tinanggal ko pala ung pipe pag iniisstart ko may tunog "blop blop" parang tunog tubig na ewan
ransell
normal lang po yung prang blop blop kapag wla pipe..check nyo po kung may kuryente.. kaht bago ang sp mo check mo pa din kung may kuyente
