HelP my T135 keep showing Overheat sign
killerdeath
Help Guyz On those who experience same problem as mine.MY bike is totally stock excep for the conical air filter.
My bike now keep showing the overheat sign when i ride my bike and rev it at high rpm.this nvr happen to me before.this sign just worry me and i think the bike performance is not that good.the acceleration decrease.I also just change the coolant after the light keep popping.but problem not solve.so guys anyone knows why?some say its due to TPS?
AZ135
The air filter is causing your carburetor to run lean and causing the engine to overheat when you run at high rpm. You need to rejet your carburetor and run a higher octane fuel.
wpt4205
you also can check whether your tps socket are properly attached, because sometime the socket loose a bit due from high rev (your riding style + Vibration)
are you sure that your coolant doesn't mix with EO?
EO also play impotant role in cooling down your engine, bcoz we do have experience using 5W-50 (Hi-Rev) overheat sign pop up then we change back to 10W-40 (motul) the sign never pop up again :mrgreen:
killerdeath
now the sign does not show.i dont know why?but my bike feels heavy when accelerating.just dont know wat is the problem.btw to those who tried to help.thank you
