Help! pop sound on my exhaust
FalangRider
Hi traxxas-modifier, i dont think you will totally get rid of the afterburning in your open exhaust pipe,this pipe has almost no esistance so some of the air\fuel mix will go out from the combustion chamber and sometimes it will ignite in your hot exhaust pipe, this doesnt happend in the original pipe because its adjuted to correct backpressure so no air\fuel mix will leave unburned from combustion the chamber.
I hope this helpend you more in your question
thanks for the info falangrider..
so far i dont have pop sound on 1/4 to Full throttle.
from idle to 1/4 there are sometimes but unnoticeable.
so no problem with that.
but yes its normal to have few pops.
but its better to have NO pops at all :)
tsunami
traxxas-modifier said:
guys just an update.
k&n newly cleaned air filter
Pilot jet = stock 20
Mainjet = increased from 105 to 110
i moved the needle clip of Jet Needle from stock (center) to top which
will make the fuel leaner.
pop sound was gone.
as previously discussed,
my problem really lies on the 1/2throttle which is controlled
by the jet needle.
anyone care to explain why pop is gone during acceleration?
where you gonna get those jetting..are there sold in indon?
wanna ask something off topic here...y if i want 2 tune the a/f mixture..it didnt rite all the time..it still have the pop pop sound a bit when i increase the idle..currently my setup is...
mainjet #110
modified stock air filter
move the clip needle to bottom
my block stock
i stepped up main jet becoz 4 me it still make my plug white brownish..
y??thanks
4kasridersclub_ph
unlimited express said:
try to adjust the pilot air screw to 2.0
Got the same pipe your about to use and better bring the default jettings back. 4N huh, nasty pipe. that pipe will unleash the power of your bike. you won't need racing CDI anymore coz 1st gear can already reach 70 kph max.
bro can 4n pipe copy the sound of a raider 150?
4kasridersclub_ph
sir traxx im looking for a pipe that can sound like a raider 150 to be installed in my t135 is 4n the right one?and one more as a stock engine what will be my max speed with a 4n pipe?
from my observation
pop during acceleration caused by too much fuel (rich)
pop during deceleration caused by less fuel (lean)
sometimes pops are caused by leaking in the exhaust pipe
especially at the joint between the engine and the pipe.
Also another caused of pops are the leaking in the Vacuum Sensing Hose (red color in drawing below)
even a small leak in the Vacuum Sensing Hose will cause Pop Sound,
so change it to a new one.
Right now, ive got no pops :)
@4kas
change to vixion block and you will have a raider sound
justkir said:
erm..im lil bit confused on the Grey hose. i tot, the hose blow air not suck air...?
its the other side blows (engine breather connection)
@junex
remove the top cover of your carb
then move the C clip to upper or lower
