thank you papayou could still use your old bearings and spacer from your stock mags sir. HTH
Bearing fittings are tight. You need to hit it to remove it.another questionabout on how to remove the bearings. ahm yes i could pay somebody to do this for me but i really want to know everything about my snipee
so i decided to DIY all the modification that will be applied to my sniper
Buy racing boy disc plate. For sure it will fit your magsHey guys,
What disc plate would fit in the rear (RB mags). I bought an RB mags recently and i thought that holes are of the stock front disc plate are in exact match to the screw holes of the mags. Unfortunately, it's not.
TIA
Thanks for answering my question. Is the diameter of RB disc plate same as the stock front disc plate of sniper? A fellow t135 told me about the stock MX rear disc and it has the same diameter. if RB disc have the same diameter, just need to choose which one is going to be more practical yet stylish.Bearing fittings are tight. You need to hit it to remove it.
but the question is if the holes of MXs stock disc fits your RB mags? that's I'm not sure.Thanks for answering my question. Is the diameter of RB disc plate same as the stock front disc plate of sniper? A fellow t135 told me about the stock MX rear disc and it has the same diameter. if RB disc have the same diameter, just need to choose which one is going to be more practical yet stylish.
Stock front disc of classic sniper is bigger than Rb disc. Try to research if it will fit RB holes.Thanks for answering my question. Is the diameter of RB disc plate same as the stock front disc plate of sniper? A fellow t135 told me about the stock MX rear disc and it has the same diameter. if RB disc have the same diameter, just need to choose which one is going to be more practical yet stylish.
If this is the case, then i really have no choice but to buy a bracket or have it modified in the machine shop. *sighStock front disc of classic sniper is bigger than Rb disc. Try to research if it will fit RB holes.
are you using stock swing arm? If you do, sold the problem of finding fitted disc break on your racing boy and the mechs can do the rest.If this is the case, then i really have no choice but to buy a bracket or have it modified in the machine shop. *sigh
The best is to find a RB rear disc for best result.are you using stock swing arm? If you do, sold the problem of finding fitted disc break on your racing boy and the mechs can do the rest.
yes, am still using stock swing armare you using stock swing arm? If you do, sold the problem of finding fitted disc break on your racing boy and the mechs can do the rest.
i guess that's where i will end up. if the diameter is different, I will need to visit the nearest machine shop here and have it adjusted.The best is to find a RB rear disc for best result.
