Help! Setting A 150cc Sniper Mx.
I need some suggestions on setting a 150cc Sniper Mx.
for daily use and long rides.
and will not condemn any other parts.
Typical Plug and Play parts with no modifications.
What set-up could be good for me?
TIA! :):):)
tabi1
pair it with smaller tire and hi speed sprocket combi, you'll definitely attain 150kph or more.
What's the deal with the smaller tire set up and getting higher top end,,, is it just less weight? Seems strange to me as any true muscle bike always use large tires, front and rear.
Definitely admire your set-up sir.. :thumbsup:
I'm not into smaller tires I want to have speed and power with wide tires. I like to bank on curves. Hehe. (Feeling racer.) :D
just ask sir odie perry sir if he has still available vixion kit. i ordered mine at sir odie and my other set.up parts. add this on your list rcdi, vixion valve spring, cams and bigger carb. :coffee:.
Thanks for the info sir.
Now I can clearly see my path to a 150cc sniper. Hehe.:D:D :coffee:
dan08
smaller tire can easily attain your top speed on a straight road surface compared to bigger tires, it can also add additional speed. when it comes on cornering it is better to use larger tires. as i have experience.
dan08
i also like to corner a lot. but my current set.up now is to attain more on top speed coz im enjoyed on NO RULES RIDE with other rider here in our place:censored::coffee:. hehehe.
True! cornering with small tires will be a nightmare that came true, right before your eyes..
Not advisable to use smaller tires on any lean angles..
oopps I almost forgot we are drifting away from the main topic. hehehe.:D :rolleyes::rolleyes:
back on the discussion vixion 57mm...
will it be high on maintenance than stock?
or will it be like stock in terms of maintenance..
(Change Oil, and other maintenance on the machine)
dan08
the most important thing is that you have a good mechanic of your choice sir that knows how on setting a vixion kit. go for 150cc modification sir. you'll definitely not regret it.
another mamaw on the making.
dan08
for my motorcycle sir, its the same on maintain as my stock. the only thing i change is that on my stock mc i changed oil every after 2,000kms or more but on my set up now with vixion kit i change oil every after 1,500kms i usally based on the odometer.
