mag racing CDI ka tapos mag jetting at open pipe mamaw na yan...goodhudas said:Hi to all MOD and MEMBERS.........
anu po pwdeng iset-up sa sniper na hindi ginagalaw ang makina?????
para bumilis ang takbo ng SNIPER ko...kasi all stock siya 115 lang kasi ang takbo mga sir eh.....
site prob dude.. auto fill ung specs d2 s t135. maaring ndi s kanya yang specs..makibaohto said:mga paps paki silip yung modification specs ni TS..now im confuse..hehehe
na naman...sorry sorry..my bad..the_one said:site prob dude.. auto fill ung specs d2 s t135. maaring ndi s kanya yang specs..makibaohto said:mga paps paki silip yung modification specs ni TS..now im confuse..hehehe
http://www.yamahat135.com/forum/viewtopic.php?t=1192goodhudas said:anu po ung jetting sa carb sir?????pasensya na po sir di ko po kasi lam un eh.....
dude_pare01 said:eto ang no worries set up ko....
sprocket combi muna...depende sa bike yan, maaring ok sa kin pero di ok sayo...pero sa stock tires more or less 15/40..kung kulang pa 14/39
then eto na...
pipe and jettings should go hand in hand
tapos kung matapang ka air filter mods then racing CDI...
kung mejo kulang pa 2 racing clutch spring at palit ka ng honda wave 125 clutch lining....
ayan motor ko...everyday service ko to work, umulan umaraw...never tumirik, pero marami ng napatirik...joke
May tulong din but basically, kuryente lang ang pinalakas mo. Minimum effect. Engine is still the same.goodhudas said:kung sa CDI, COIL, SPROCKET, SPARK PLUG po muna i set up ko po ok pa rin po ba???
ganun po ba sir.. salamat sa info... ride safe..wingman44 said:May tulong din but basically, kuryente lang ang pinalakas mo. Minimum effect. Engine is still the same.goodhudas said:kung sa CDI, COIL, SPROCKET, SPARK PLUG po muna i set up ko po ok pa rin po ba???
Also, be wary of using Racing CDI's with stock engine. This could cause a problem to your engine.
I'm not trying to scare you guys. This is very real.
sir ung 115 mo eh.... lagpas 120 sa ibang MC... hwag ka magrely sa speedo mo...goodhudas said:Hi to all MOD and MEMBERS.........
