sir chig.. about your suggestion is it good also when you add racing cam?chiglai said:how about bigger piston without carb upgrade? for sure mas minimal ang gasto sa bigger piston using stock carb compare to bigger carb with stock piston, and for sure mas malakas pa bigger piston w/ stock carb compare to stock piston and big carb...
+1......ok to..chiglai said:how about bigger piston without carb upgrade? for sure mas minimal ang gasto sa bigger piston using stock carb compare to bigger carb with stock piston, and for sure mas malakas pa bigger piston w/ stock carb compare to stock piston and big carb...
rejet nalang ung stock carb + vixionkit + vixion cams at the moment hehehe..then replace it with yypang cams or fcc icams in the futurechiglai said:how about bigger piston without carb upgrade? for sure mas minimal ang gasto sa bigger piston using stock carb compare to bigger carb with stock piston, and for sure mas malakas pa bigger piston w/ stock carb compare to stock piston and big carb...
i agree!raider125jeigh said:rejet nalang ung stock carb + vixionkit + vixion cams at the moment hehehe..then replace it with yypang cams or fcc icams in the futurechiglai said:how about bigger piston without carb upgrade? for sure mas minimal ang gasto sa bigger piston using stock carb compare to bigger carb with stock piston, and for sure mas malakas pa bigger piston w/ stock carb compare to stock piston and big carb...
vixion block kasama piston saka piston ring...vinz0r said:ano un pre stock ng vixion? head, block, cams? carb? anu anu?
