wowhgm pipe tear drop user here...very good performance with brt hyperband,namban ignition coil,iridium,cms valve spring & keihin carb![]()
sir I also use HGM tear drop but my engine is stock is it fine? or will I be facing troubles in the future? soundwise is very-very fine and im ver satisfiedhgm pipe tear drop user here...very good performance with brt hyperband,namban ignition coil,iridium,cms valve spring & keihin carb![]()
it has no problem on stock engine.. but you need to change the rcdi, ignition coil, spark plug & tune up the carb for better performance of the T135 enginesir I also use HGM tear drop but my engine is stock is it fine? or will I be facing troubles in the future? soundwise is very-very fine and im ver satisfied
ride safe infinity01
thanks papzit has no problem on stock engine.. but you need to change the rcdi, ignition coil, spark plug & tune up the carb for better performance of the T135 engineride safe infinity01
is der any prob. boz if u dont change the parts mentioned?it has no problem on stock engine.. but you need to change the rcdi, ignition coil, spark plug & tune up the carb for better performance of the T135 engineride safe infinity01
i dont expirience any problem using hgm big elbow on my stock engine it performs very well specially on out of town roadtrips you will love the roaring soundis der any prob. boz if u dont change the parts mentioned?
thankzz
Thankz @marulas4kasridersclubi dont expirience any problem using hgm big elbow on my stock engine it performs very well specially on out of town roadtrips you will love the roaring sound![]()
mine is all stock except the sparkplug im using denso iridium plug..its up to you if you have budget for upgrade buy aftermarket parts..my sniper HC is going 5yrs this coming AUGUST 16...( 2008 model) i didnt encouter any engine problem except my acceleratorpump rubber cap is broken due to wear , my bike is my daily service for work and for my touring bike with my club buddiesThankz @marulas4kasridersclub
how about without changing this parts rcdi, ignition coil, spark plug?
thankz papz coz i dont have plan to change any partz only mine is for good apearancemine is all stock except the sparkplug im using denso iridium plug..its up to you if you have budget for upgrade buy aftermarket parts..my sniper HC is going 5yrs this coming AUGUST 16...( 2008 model) i didnt encouter any engine problem except my acceleratorpump rubber cap is broken due to wear , my bike is my daily service for work and for my touring bike with my club buddies![]()
and i am SMX owner in just a month
0I got to have someone beside me on the road who uses this type paps. I sounded it and I think it's same with mine (tear drop). How about the performance? TIAi got the gunmetal canister since way way back 2010 till now... as mr. peter john dionisio would tell, " rare " ... my hgm pipe is not commercially mass produce currently... its a semi big elbow not like the gp type and way different of stock elbow of hgm...0
