Hi Comp My X1r 135 And Pnp? Is It Okay?
MazeVR46
help guys. my x1r is still all stock.
is it okay to hi comp the engine?
what are the advantage / disadvantage?
and about po sa carb? what is rejet means? can stock carb can be rejet? is there any advantage?
thanks! im new here. im from quezon city fairview. im willing to meet any people that can help me.
Paladin
Better get a trusty mechanic who will do high comp your engine. Pros, you will have more power and top speed. Cons, your engine is prone on knocking if not done properly. Carb size depends on you setup. Rejet is about the sizes of jettings to fix the mixture of the flow of fuel and air on your carb.
MazeVR46
ahh gnun po pala. sir can you help me to do this upgrade? haha. :)
SaM03
tips, just try to remove the base gasket its safe.. =) if you still want to have the base gasket just shave off your block about 0.5mm
MazeVR46
ahh okay lang po ba yun? remove base gasket? pwede nmn po ba ibalik yun? nakakatakot po kasi yung shave. wala akong kilala na kayang gumawa nun. salamat sa tips.
MazeVR46
MazeVR46
thanks! but i dont know where are the masters of t135 that can do that here in quezon city. :( please give me some advice where they are. :))
MazeVR46
t
tex me.. 0929-658-6174.. ikaw ba ung taga atherton????
taga sss subd. lng ako. katabi lng ng petron. san ka sa sta lucia? papagawa ko kasi hid ko dba sabi mo mron mekaniko dun? tayo yung nag kita sa petron nung gabi dba?
ash
t
Tx moko ..may kilala akong gumagawa ng HID..
0929-658-6174
jangbest
kung nakacam at rcdi,safe pa rin ba sir?
We are on english thread bro you can use your english carabao here..
anyway .....yes it`s safe using cams but it depends on what your cams is using
maybe you need you valve pocket your piston to avoid valve's kissing piston.
