HID issue
thon
I`ll change my ballast cause the damage wire is in the bottom edge of ballast,trying to fix to connect it again,but sadly,the spark comes out from the broken wire insolator and also electrical tape is not enough,you hear the tik tik sound cause of spark comes out from the wire to the nearest ground (the electric comes out from wire is high voltage
Well said bro, connector from ballast to bulb is about 24kilovolts.You can use epoxy to insulate broken wire.
suiluj
thon it is ok to cover epoxy the wire from HID bulb to the connector to ballast? may be my hid bulb wire have bad connection/wire, i see a puncture near the connector.
zeth2884
sir help nman po my motor is mio sporty nag install ako ng high h.i.d ang naging problem ko ay pag na rekta namamatay ang h.i.d then pag nag busina ako biglang iilaw ulit hel nman po
zeth2884
for those persons who doesn't have time to do there DIY regarding the HID:help: and willing to pay a few bucks,:) kindly txt this #0916-3015044 if you're near in makati and manila area. experience the HID without low bat and added accessories like fast charging etc.. j villa motorcycle shop...... nice shop, good service honest mechanic the guy is good in any electrical problem :dance:
sir magkano po binayad mo pa kabit kay j.villa ng h.i.d??? makati din ako sir
guitarizta
when installing HID, you must convert your wirings to battery operated. And you should convert your MC to fast charging coz HID consumes alot of power.
zeth2884
yes sir i have converted my h.i.d to battery operated.. then my only problem is when my motor is when my motorcycle go o high rev my h.i.d will turn off.. sir do you have diagram on how to install h.i.d (high only) so i can foolow/ tia
thon
Did you cut the yellow wire in the rectifier bro?
It seems that the voltage generated is more that 15 volts which cause HID to auto shutoff.
zeth2884
yes sir i cut the yellow wire.. so ibig sabihin sir nag overcharge?? kaya nag shut off ang h.i.d? sir pls help me to fix it...
thon
sir i hope that you can help me to fix my h.i.d installation...
You need fast charge regulator/controller bro, fast charge regulator will disable fast charging when 15volts set voltage exceeded.
Im willing to help you bro but im in cavite, your from makati right?
zeth2884
yes sir im from makati near cash and carry.... saan po ba kayo sa cavite?
JVIC
mio 1 2 3 at vega force, sniper crypton yan mga nakabitan ko na yamaha so far so good walang nalolowbat
sir john carlo pwede mag pa ayos ng hid ko nalolowbat kc lagi eh.ako po yung pumunta sa inyo dati yung bumili ng stock rotor disk nyo.kailan po kau free???gud dy
jhetzki21
i got the same problem sir on my motorcycle when i cut the "yellow wire" the thing is when you cut your yellow wire. the charging current is not stable and yes it exceeds to 15Volts. what i did was i bought a diode here on one of our local electronic store . i don't know what diode it is but what i said to the saleslady was "pabili po ng diode yung pang motor" it cost me P15.00 only. so after i put the diode on my yellow wire (remember that the diode has polarity) after that i tested my charging while revving realllllly high and i only got 12-13volts. idle is 11-12 volts. i tested it with my digital multimeter.
