HID issue
jefplacido
HID wiring posted was done on my MC and working w/o lowbat..;)
I just want to share my ideas to those who want to DIY ..hehehe..:D
thanks sa pagshare ng info bro
ako na magkakabit ng HID ko,hehehe,sana masundan nkong tama yung step by step procedure...
big thanks!:);):shag:
thon
papa thon dito sa pics sa baba dalawa na yellow wire ang ikakabit at kahit ba mag ka baliktad...
@ mhektheone When you cut the yellow wire your headlight will no longer turn on even headlight switch is on with engine running. Turn off engine then connect brown wire to yellow wire going to switch, if headlight switch turned on and your headlight and park light turned on then your MC is now battery operated.:)
thon
base on the picture of your fast chaging rectifier,yellow wire ang pinutol at kinabit sa spdtbkit yung s akin black wire ng rectifier ang pinutol pero so far so good nmn...walang lowbat....ok lng b yun?
Cutting the black wire will also convert our mc to fast charging. Ito ginagawa ng iba lalo na pag dual HID gamit nila..:D
ronald031803
so mas malakas pla pg black wire ang pinutol...tnks for the info paps...
yes paps,malakas mag charge pag black wire ang pinutol mo,yan ang ginawa ko nung naka hid pa ko,malakas din uminit ang rectifier,up to more than 18volts ,
beware to your CDI,lalo na pag nag blown ang fuse ng di inaasahan,sumasabay sa revolution ang pag taas ng volts,for now back to bulb muna ako ,i used OSRAM bulb sa head light,
stay battery operated ang line ko except sa headlight na ginawa kong magneto operated
thon
ronald031803 you encounter busted CDI due to blown fuse?
When our mc main fuse blown, overvoltage will happen and CDI will be on danger since theres no battery that will absorb excess voltage from rectifier.
What I did on my mc is to put diode and capacitor going to battery from contact #87. This diagram does not assure that CDI will not get busted when fuse blown but this is what I did on my MC.;) diode going to battery.jpg
ronald031803
What I did on my mc is to put diode and capacitor going to battery from contact #87. This diagram does not assure that CDI will not get busted when fuse blown but this is what I did on my MC.;) View attachment 16938
good for you,,good luck to your circuit diagram,,,,,,
mine is back to stock rectifier to avoid any electrical problem
HID put back to their box and keep in cool dry place,hehehehe
ayan, lumabas na ang sikretong malulupet. may diagram na. :) gandang info nito. ayan, DIY na. BTW sir, itong diagrams na ito, automatic back to normal charging ba pag di buhay ang HID?
thon
yes.;) Fast charging if HID is on, normal charging when hid is off.
nyr0
paps anu po ung OSRAM bulb? plan ko din kasi magpalit HID busted na kasi headlight bulb ko.. tia!
ronald031803
osram -brand yun ng head light bulb mas malakas ang liwanag nya ng 30-50% depend sa klase
me silver star +50% ang brightness nya,all season super yellowish sya +30% ang brightness nya & super white
