HID issue
agent*mike
what brand of fast charging rectifier do you prefer?? i need 1 Brand new set of HID plus fast charging rectifier and expert electrician,, wala po bang nakalimutan?? or may iba pa pong kailangan??
Use stock rectifier, when choosing HID brand use only "Perfect". Do not purchase cheap HID because it will not illuminates High discharged lighting.
agent*mike
what brand of HID do you prefer sir mike?
Before, best recommended is Bosch. But the distributor changed the item label, you maybe heard "PERFECT". There are only few items left in the market because the distributor is no longer importing such high quality ballast.
emerson
you mean perfect light sir mike?? if im going buy and install to mechanic an HID light do you i need to changee my rectifier to fast charging rectifier??
agent*mike
Yes, but they have variety of HID ballast. Simply choose Perfect brand. No, you don't need to replace your rectifier. It's perfectly design to sustain your high electrical needs.
suiluj
Some body know how to fix my HID problem. my HID will not Turn On after i used for less than 1 hour. it only happen when i switch off my Engine then when i turn on again my HID will not light. some sound i hear like grounded. day later it will switch on again my HID will light. my battery is in good condition not lowbat.
agent*mike
As what I replied in the other forum, try to replace your bulb. It will surely solve your problem. I'm maybe wrong but I am 90% sure.
rhoitol
it is possible that the hid, panel lights and the ordinary bulb are battery operated and the park lights were stator operated?..
btw, im using X1r headlight..tia..
nyr0
ronald031803
thnks for the quick response sir! i think he is really busy right now.. i just thought you could give me other potential seller or market for this bulb BDW im from bulacan
rich_havens
yes i guess this is possible... even the other way around... battery operated park light stator operated panel light
ronald031803
ronald031803
only in caloocan 9th ave. racehub and line of store shop here from 9th to 10th ave,,,west side of rizal ave.
