HID problem(ENGLISH PLEASE)
ronnelmarc_21
sniperyaz said:
HOPE THIS WILL HELP FOR THOSE WHO WANTS TO USE HID IN NO LOWBATT INTO OUR T135
GUYS CORRECT ME IF IM WRONG RIDE SAFE TO ALL
in my case sir,,fast charging will be activated only if HID is ON,..if ur HID is OFF,..your charging is normal just like the stock wiring,..
sniperyaz
do we have the same settings sir? or your HID has an added gadget that provides a fast charging?,,, i saw somewhere here in the internet that there's a new version of HID launched here in the philippines that has an added gadget. that gadget will activate when the HID is on and it will deactivate when your HID is off, for my settings this was an old modz,, and this modz for those who cannot afford that gadget,, sooner or later gonna buy that thing, for now i need to save money for that thing.. :lol:
ronnelmarc_21
I just made a simple gadget and installed it together w/ my HID sir,..me too sir I saved my money so I came up w/ this solution,..
sniperyaz
ronnelmarc_21 said:
sniperyaz said:
[quote="ronnelmarc_21":32b2hy0h]
I just made a simple gadget and installed it together w/ my HID sir,..me too sir I saved my money so I came up w/ this solution,..[/quote:32b2hy0h]
cool! so you are a inventor?? hehe,, what design you made dual rectifier? one is for fast charging and the other one is stock? then if you open your HID your fast charge rectifier will activate then the stock will deactivate vise versa
chuki2
ronnelmarc_21 said:
sniperyaz said:
[quote="ronnelmarc_21":25n95pd9]
I just made a simple gadget and installed it together w/ my HID sir,..me too sir I saved my money so I came up w/ this solution,..[/quote:25n95pd9]
Errmmm....I think u just using relay right??when HID on,just CUT black wire by relay on Rectifier??Then when HID OFF,black wire will connect back by relay??correct me if wrong..thank...
ronnelmarc_21
chuki2 said:
ronnelmarc_21 said:
sniperyaz said:
[quote="ronnelmarc_21":2acmmvlx]
Errmmm....I think u just using relay right??when HID on,just CUT black wire by relay on Rectifier??Then when HID OFF,black wire will connect back by relay??correct me if wrong..thank...[/quote:2acmmvlx]
your right chuki,..but be careful,..this kind of setup is really a fast charger,..if u use the black wire,..you might have over voltage at high rpm,..causes your HID to shutdown at high voltage,..you can use also the red/yellow wire like what I told you before.
ronnelmarc_21
Auto Fast charger Diagram,..
Description: Fast Charger will be activated if HID is "ON",,normal charging if HID is "OFF"....for single HID headlight only.
Sidro
wow!! sweet.............. very very good job, despite I cant view it from here, but I think this another master piece of einstein!,, este!! ronnel... :mrgreen: :mrgreen:
ronnelmarc_21
hahhaha ur funny papa Sidro,..I know that you dnt need to view the schematic coz you know how to do it,..
sniperyaz
sir can you give us an actual picture of that diagram like i did step by step,,, would you mind sir? TIA
chuki2
[/quote
Sir..wanna ask to you..can we using 2 HID in same time?
I think is can right?
botsok
please help me.. i'm having a problem with my HID.. it works propoerly at idle, but at high RPM, my HID turns off,, and turns on again if i press the horn or if i go slow (or low rpm)
