guitarizta
Bro according to what I've seen on my bike (I think it is typical to your too) and on my diagram.
Yellow/Red - Power supply coming from stator/rectifier
Blue - For Auxiliary/ Park Light
Blue/Black - from Head light switch going to your Hi/Lo switch
On the Hi/Lo HID, the trigger should be on the Hi/Lo switch.. Actually the Hi/lo HID kit is just plug and play..
The red and black (with fuse) are to be tapped to the battery terminals.. Red (Positive) & Black (Negative)
The other two wires of your HID kit (blue and white) are for the High beam and low beam respectively..
Tap the blue wire of your HID kit to the yellow (HI) of your bikes Hi/Lo switch and the white to the green (LOW)..
You're understanding is correct..
HTH
