HINDI DAW APPLICABLE IPA PORT UNG INTAKE
turok
GUYS AND MASTERS nid help bout this... i nid to know if this is true....
lately ive been having a problem with my mc, and it all started when i change the valve spring to (LHK brand) and i have it ported and polished.....
and the result is that, my rev limit became short.....I if its the valve or the brt neohyperband rcdi..!
and, someone said the our intake is not applicable to be ported (BABAGAL DAW)..... and that the solution depends on the pipe.......
IS THIS TRUE.......
mrgabrieldiaz14
pwding iport ang sniper... gud news that ur rev limit bcome short, meaning lumakas ang motor mo kc mas madaling tumaas RPM ng motor m. buy k nlng rcdi para m solve ung rev limit ng motor mo...
noi
nangyari nayan sakin paps..... valve spring ang deperensya ng motor mo paps...
since LHK gamit mo valvespring, malambot yan paps keysa stock na valve spring
try mo paps ibalik mo stock valve spring mu......... ok n yan..
ok lng ang port bsta maganda pgpagawa.......
kaya ako vixion valve spring gamit ko....
Arkrye
and wer do u find that one???hehehe..
better your a satisfied vixion v spring user.. :D
rr117-sacker41
paps copy & paste ko lng yung sinabi ko sayo sa isang topic mo about brt cdi
@ turok
same experience bro. brt rcdi user din ako dati. i've started the problem ng magpaport & polish din ako. hindi advisable para sa ating engine ang iport ang intake ng cyl head (lalo na kung stock block pa gamit mo/ok cguro kung 61mm block gamit mo). hihina na ang power at lalakas pa ang fuel consumption ng engine natin.
pero may solution dyan......ang sekreto nasa pipe mo.
Ganito yun paps:
since nakaport na ang intake ng cyl head mo at ngayon naramdaman mo umikli ang rev limit ng motor mo, may mga paraan para maibalik o mahigitan pa ang dating lakas ng motor mo. Dapat maging member ka ng MAD (modification addiction disorder) at ngayon pa lng alam ko nag-uumpisa ka na maging MAD.
magpalit ka ng mga sumsunod:
1. engine block 57mm - 59mm - 60mm or 61mm depende sa set-up na gusto mo.
2. valve spring - vixion or yypang
3. racing clutch spring
4. bigger carb- 28mmcarb ok na
5. exhaust pipe
last mod mo ang pipe kc hahanap ka ng pipe na tatama sa tono ng modified engine mo. hehehe...o ayan gets mo!
cgurado sibak na ang r150 sayo nyan. :D :D :D
turok
tingin ko rin pre valve spring ung problem... kc bago ko ipakabit natry kong pigain ung stock saka yung lhk..
mas matigas nga ung stock.... pero ung lhk parin ung pinakabit ko sayang ung pera.....
anyway thanks man..
san ba nakakabili ng vixion na brand.....
turok
Ganito yun paps:
5. exhaust pipe
cgurado sibak na ang r150 sayo nyan. :D :D :D[/quote]
mukang MAD na nga ako.... hihihihihihihihihhi
d naman cguro pero k lang nman. anyways salamat din kaso lang medyo expensive ung mod na cnasabi mo.....
axon
IS THIS TRUE.......
una hindi ako master, but in my humble opinion, polish lang sa port ang ginagawa ko hindi ported, exhaust side lang ang port n polish, subukan mong humitit ka sa matabang tubo, o hose di ba mahirap, humitit ka sa straw di ba mas madali,at mas mabilis? depende kung gaano ka kalakas or gaano kalakas ang makina mo, so it means nag kakaroon ng air velocity computation gaano ba kalakas ng makina mo para mag palaki ng intake? our intake side is more than enough to supply your stock engine or slightly modify, hindi mo basta nag poport lalo na kung di natin , naiintindihan ang kung saan parte binabawasan, in my profile newbie po ako, ikaw na bahala kung maniniwala ka sa sinabi ko, just wanna share my experience hirap ng masabihan ng HUMBOG ni rjloks....kaya rjloks mag iingat ka sa mga sasabhin mo dito, di natin kilala kung sino nasa mga likod ng username he he he... :evil:....check link below....
viewtopic.php?f=25&t=6391&start=160
KupaX1r
ako eto setup ko,
brt dualband, crg clutch spring, port and polish, 28mm carb, camshaft, HGM open pipe, stock valve spring, stock bore(balak pa lang bumili ng 61mm)...
maganda nmn ang takbo, tumatakbo ng 80 km/h 2nd gear, yun nga lang ang lakas ng lagitik sa makina, maingay ang makina,
normal b un?
rr117-sacker41
kupa said:
ako eto setup ko,
normal b un?
over rev....(ingat paps bka ka matukudan)
go for vixion valve spring
KupaX1r
rr117-sacker41 said:
kupa said:
ako eto setup ko,
normal b un?
need b tlga palitan ang valve spring?
rr117-sacker41
sniping_area said:
para sa akin bawal ang port sa mga walang pera ipangport!! yun lang...
korek ka dyan!!!
porting of intake...pinalalakas mo lng ang gas consumption mo..tapos kasunod nyan bigbore na hahabulin mo na ngayon ang kinakailangang power na iniisip mo para sa mc mo...
o ayan dapat madami ka peraaaaa..... :) :) :)
Sidro
[quote="sniping_area":1y8xj5da]para sa akin bawal ang port sa mga walang pera ipangport!! yun lang...
korek ka dyan!!!
o ayan dapat madami ka peraaaaa..... :) :) :)[/quote:1y8xj5da]
hhhmmm, subscribing lang.. unti unti ako nalilinawan..
galing ni papa rr, nice meeting you paps yesterday.. hehehe
benta natin motor natin para may pang PnP? :twisted:
@ryjae: "just a newbie opinion" hahahaha,,, you know na.. :twisted: :twisted:
