How To Check Regulator/rectifier If Broken
mac kevin
worse if he installed HID bulb without cutting yellow wire and converting to battery operated... I say this one coz i remember "my very smart" neighbor, its about 3 years now, he directly installed his newly buy HID bulb to his mc (not sniper), w/o cutting the right wire from stator and converting to battery operated..., the result, HIS BATtERY is ALWAYS DRAIN...
kikaipitoy
H
You have problem on charging system ,check wiring on charging system, check rectifier& stator
with no battery measure the output of rectifier (red&black terminal) you should get more than 12volts DC at idle. Do not do this test at high rpm for longer period of time to prevent damage to the rectifier/regulator.
Hi Sir @thon is it possible that I can start my MC without my battery? So far cant start my MC without the Battery...is it because Im using RCDI? TIA
thon
H
Its not posible sir, tried it before using rextor cdi, i cant start my mc without battery but using stock cdi i can start my mc using kick starter. Not tried using BRT cdi.
kikaipitoy
ok thats it...Tnx Sir @thon...its confirm that using Rextor and BRT CDI wont start our MC using the kick starter...im just glad to know this...
