How To Clean Sss Chain For T135 And Which Specs Are Better ?
phuc9867
Hello guys , I just bought SSS sprockets and chain kit t135 . The size of the kit is 5 mm , 415 I think [ The chain and sprocket ] . I've heard the seller said to me that SSS chain has some kind of rubber ring in it [ I don't know what that call in English , Sorry guys ] . Is that true sss chain has rubber like O-ring chain ? And how do I clean it ? I usually DO oil [ Diesel ] to clean normal chain . Please show me how to clean to keep it shiny and new and do not ruin the rubber if it has. :D Thanks
BTW , which one will win is the drag race with these specs :
#1 bike [ mine ] :
T135 2011 new model
135 cc ,
stock carb ,
stock air filter ,
stock ecu
racing boy sport rims 688 ,
Tire: front 70/90/17 , rear 80/90/17 .
Sprockets : 14 - 41 428D chain [ 9 mm ]
Many Custom racing clutch . [ Don't know how to write this detail ]
If I change the sprockets to 14 - 39 415 [ 5mm ] will this specs faster that the one I'm using right now ?
And can that beat this t135 below ? :[ with new 14 - 39 415 [5mm] sprockets
#2 bike :
135cc
stock air filter
stock engine
Full racing iginito , iginition coil , denso power spark plug .
stock Rims.
Stock tires .
Stock clutch
Using racing boy auto chain tensioner .
Stock sprockets - chain .
Thanks to all viewers and commenters :D
WawardTy
@phuc9867
Hi phuc,
i am also using SSS chain and sprockets. I usually clean them every 250-300kms of use using a clean rag with kerosine to remove the sludge and dirt that accumulates on the chain and gear teeth. Just place the bike on centerstand and you can repeat the cleaning process using rags+kerosine until no dirt remains. After that spray the chain evenly with "chain lube" to provide lubrication and protection.
And about the drag race, if the riders weight are equal and both carbs are properly tuned i think setup#2 will win if what you mean with "full racing ignition" is racing CDI along with the coil and wire, because that setup can achieve higher rpm [up to 16000rpm ;depends on the manufacturer] and better combustion compared to the stock cdi [up to 8000rpm only]. IMHO:)
Hope this helps. Ride safe.
