i just want to know how to connect a standard analog tachometer or rpm gauge on my sniper. anyone have known? just please give some diagram connection of the 3 wires. thanks
so what is more accurate between the two methods? and what type of tachometer should i buy if i am planning to do so?how accurate is it? what is the range of tachometer should i used?
it also depends on where and what brand tach you get. I just installed a Type R on my bike and the Black wire was the Positive to ignition wire, yellow with black stripe was +coil, green was - coil, and the redish brown was light switch. ask the shop that you get the coil from which wire's are for what. it makes it much easier.
nice topic! how about installing yamaha 125ZR (thats what we call it in malaysia, 2-stroke 125cc bike) tachometer? can anyone post some HOWTO? the wirings,etc...
