turbulence
yes sir. but make sure not to over rev your engine for longer life. Don't full throttle your lower gearsok,it means.eventhough my engine is stock,i can use rcdi?
y?what will happen if i full throttle?yes sir. but make sure not to over rev your engine for longer life. Don't full throttle your lower gears
ah tnx bro,a technician/mechanic told me that i should use rcdi,to attain top speed eventhough my engine is stockdo you know tukod that will hapen if you full your throttle, masters recommend to use aftermarket valve spring to hold the high rpm,
correct me if im wrong master's..
over rev may scratch your block or pistonwh
GSD or MOTO CORSA,im looking for a trusted and a good mechanic when it comes to engine mods,I'm planning to replace my stock cdi to rcdi,and to add aftermarket valvespring,what brand should i use bro,and where can i buy them?
where is the place of moto corsa and GSD??GSD or MOTO CORSA,
I'd like to add one more if you wouldn't mind... "LOSE WEIGHT"(that's what I'm tryin to achieve right now.. )
Nice info SirStage 1 Minor Mods
Exhaust System - Boost Acceleration & Power (AHM M1/CF)
RCDI - Boost Max RPM (BRT Hyperband/REXTOR V3)
Valve spring - need when changing RCDI (TK/CMS/FAITO)
Clutch Spring - Improve the Performance (FAITO ZERO)
Sprocket Combi - Acceleration (FAITO/SSS)
Stage 2 Basic Engine Mods
Camshaft - POWER & Acceleration (TURBO CAMS)
Ignition coil - Torque & Power (FAITO 7400)
Plug wire/Plug Cap (HTW) - to support ignition coil (FAITO Twin Core)
Iridium Spark Plug - Torque & Power (NGK/DENSO)
Clutch plate - Improve Performance (FAITO THUNDER)
Racing engine Bearing (FAG/FAITO)
Stage 3 Engine mods
Port and Polish
Crankshaft - Stroker (FAITO 3.5mm)
Bore kit - Engine displacement (Vi-xion57mm or Faito 60mm)
Carb & Jettings (Keihin/Mikuni 28mm)
Valve set (Faito)
Timing chain - use when changing crankshaft to stroker shaft (Faito)
Stage 4 Engine mods Final stage
Racing Gear set "Tranny" or Gearings (Faito)
