How to make your stock bore 135cc goes to 135-140kph
SPEED RACER
wow ! heavy hitter:D
thats why u upgrade to bigger bore
ya that's y i upgrade bigger bore co'z im not satisfied stock more i want more power, im planning to order big valve 23/19 & also change my 4 gear to 21teeth, 28mm keihen carburator..
ONE3FIVE
How to make your stockbore runs from 135 to 140kph (philippine/indonesian specs) with GPS of 128kph
Hi all,
We all know that the 100% stock T135 can reach average speed of 115kph(gps speed of 105kph)
Some also can reach 120kph (gps of 110kph)
The goal of the YamahaT135 forum is to share knowledge on how to make the T135 bike maximized its capabilities and unleash its power!
So with the help of the forumers, I am sharing this guaranteed modification
on how to make your T135 maximize its performance on a stock 135cc bore. Thanks to you guys for sharing all the mods and tips thus i am applying this and showing the video.
This is for educational purposes shared to you.
T135 all stock topspeed
http://www.youtube.com/watch?v=jAQfTs8u61E
[flash width=480 height=385]http://www.youtube.com/v/jAQfTs8u61E?fs=1&hl=en_US[/flash]
and if you want more speed, Modding T135 bike with
Specs as follows
-Stock bore 135cc (not modified)
-stock head (not modified)
-stock front tire 70/90x17
-stock rear tire 80/90x17
-stock sprocket 15/39
-stock carb VM22 (22mm) on stock airbox
-rextor cdi
-vixion valvespring
-r9 exhaust pipe
-kawahara K1 racing camshaft
-removed the decompression pin
-protec groundstrap racing coil
Test site: around 2kms stretch (plain leveled road)
Checking the Top Speed
http://www.youtube.com/watch?v=-4LeXpQoA6s
[flash width=480 height=385]http://www.youtube.com/v/-4LeXpQoA6s?fs=1&hl=en_US[/flash]
Checking the RPM vs Every Gear Speed
http://www.youtube.com/watch?v=PNpCjsR-n9M
[flash width=480 height=385]http://www.youtube.com/v/PNpCjsR-n9M?fs=1&hl=en_US[/flash]
The video shows that the T135 bike can reach 140kph (GPS of 128kph) or more!
The above specs is just an example and it works on our test bike.
Some other brand parts can also give same or much better power or poor power,
You just have to experiment and try and compare all of it.
You can also use sniper31's tried and tested super-hilift racing camshaft what they
called "pan-asean cam". You just have to be careful on pan-asean superhilift cam when installing.
If you want more speed
you can use other mods like bigbore kit, highflow airfilter, bigcarb 26mm or bigger,
head porting, removing base gasket, etc..
Hope that this video will help you especially the newbies and veterans
afraid of modding their beloved bike :D
MOD YOUR BIKE NOW!
how much it will cost idol
JUNEX
CHECKING....
O-Stock bore 135cc (not modified)
O-stock head (not modified)
X-stock front tire 70/90x17
X-stock rear tire 80/90x17
X-stock sprocket 15/39
X-stock carb VM22 (22mm) on stock airbox
O-rextor cdi
O-vixion valvespring (TK)
X-r9 exhaust pipe(YYpang)
O-kawahara K1 racing camshaft(Brandless)
O-removed the decompression pin
X-protec groundstrap racing coil (back to stock.. damage)
aklan
O-brt powerband
O-mtrt valvespring )
X- exhaust pipe(dbs)
O-faito s4 evo racing camshaft(Brandless)
eto sir for example gamit ko ano gaano kaya tatakbuhin neto?​
nguyenquan1
" stock bore 135cc goes to 135-140kph " in stock counter-meter ? --> It's easy, you just need a long straight road .
But " stock bore 135cc goes to 135 kph in GPS speedometer " , it's ...... I don't know how !
aklan
sir trax need help i got my racing cam valve spring r cdi
but my speed was same as on my stock settings.
info: vpocket 2mm 10in 15 exhaust stock carb stock sprocket tire 70/80 80/80
what can you advice about my settings to increase at list umabot man lang 135 speed ko sir>>.......:(
vhadz
bro aklan, hi bro,
bro as we said in other thread need more space or clearance vlaves mo, if ur using cam kahit stage 1 p, kailangan ng sounds n tiktiktik, if higher lift cams it tikkitikkitik,
keep this as your starting point bro, rcams need r-valvessprings need clearnce in order to play..
ha ha ha i'm not a master pwede master sardines na kabarkada ni 555 at century tuna ha ha ha ha:D everyone can do it, and everyone can destroy it , kaya we got 2 meaning of DIY
Do It Yourself and Destroy It Yourself, yes motto lang yan pero yan ang totoo rigth?
in connection sa project, computation na ako sa compression ratio , and valve ratio to piston size,target intake and exhaust valve unknown
here the example i used and try to analyze it, why i need 23/20 and not 22/19 based on oem sizes sa mga newbie he he he para maunawaan natin kung bakit tayo nag papalit ng big valves this is one basic reasonwhy ....everything in engineering involve ang math and this sniper engine is a basic example of 4 stroke with 1 piston 4 valves and 1 cam, :)
on stock
bore =54mm
in =19mm
ex = 17mm
on intake side first,
54bore /19intake = new bore 65/new intake size=X
simple equation for X
x=19mm intake x 65mm bore /54 oem
=22.85 mm intake for new 65mm piston
same formula i used for exhaust side
54bore /17exhaust =65bore /x
x=17mm ex. x 65mm /54 oem
=20.4mm exhaust
even we used ratio between bore and intake of stock and bore intake of new bore kit with above result
54/19=2.84
65/22.8=2.85
http://www.yamahat135.com/posts/368954/
CLICK MO LNG UNG MGA LINKS MAKIKITA MO AI ESTE MABABASA PALA MGA BIDA S TELESERYE, WEHEHE:)
bro this info: vpocket 2mm 10in 15 exhaust stock carb stock,or set of yours u cant go higher than 130, there is still more to do about it, here ill show u some links,
thttp://62.0.5.136/www.yamahat135.com/attachments/img_4685-jpg.10755/
SANA MAKATULONG BRO, RIDE SAFE,
vhadz
@ bro aklan, yang c rowan isa s mga maestro yan d2 s t135, apprentice lng aq d2, ride safe bro,
docgabby
damm!!! your bikes are super fast! my daily driver wont be able to catch the speeds you guys are running!
aaakirasan
X-stock front tire 70/90x17 ( 80/80x17
O-stock rear tire 80/90x17
X-stock carb VM22 (22mm) on stock airbox ( OKO 3omm )
O-Rextor V1
X- exhaust pipe( AHM )
O-faito s4 evo racing camshaft(LHK)
X-protec groundstrap racing coil (hmmp..)
145 kph...
