Hello, could someone post a video/picture/guide on how to remove the spark plug.. the spark plug location is quite deep and tight, also some kind of pipe (i think radiator pipe) is blocking it..
remove also the connection of the black pipes near the radiator for you to have a room for turning your sp makes sure to put it back the way it used be connected after your done
to remove sp twist it counter clock wise the and the other way around when you put it back
BTW there is a tool in removing uru sp when you bought ur bike the long round tube that has 2 holes at the end insert that in ur sp and use screwdriver to twist it then
ur bike is destroyed already hehehe
just kidding
try it very easy
