Howto: Lightened Magneto/Rotor
sir traxxas...does it has any -ve effect??
is 2mm is to much???
wasn`t it will be toooooo light for the engine to hold??can the timing chain snap???
this what i have in mind..n still thinking...
if it ok...then i just want to go for 1mm or 1.5mm...hehehehe
thanks.
tashrey_888
bro im happy with the acceleration ,but theirs a problem with your charging system .... especially if ur using hid... its a big drop of voltage when putting on the hid...
yeah...??thanks for the feedback...i will done this mod in about a month or two from now..coz now is really bz for me.....but only 1.5mm or 1mm only...ehehhe...
bro tashrey
i could not see the reason why theres voltage drop in charging.
charging system is on the magnet (inside the rotor) and not on the outside where you shave off.
in electricians point of view theres no reason why charging system will change.
im using HID since then and no problem at all.
if you have charging problem, there might be a burned wire in your stator.
let us know bro sniper31 :)
A/C motor and H/C has the same magneto rotor so yes it can be done on A/C
tashrey_888
my electrician said once you shaved off the magneto it change the revolution of momentum of some sort...ill just check my stator if i have time next week...thanks bro...ride safe everybody
yes bro it will change, but its the opposite.
reducing the weight will infact produce more rpm thus more turns = more charging.
remember the purpose of lightening the stator is to have more and quick rpm than stock stator.
HID lowbat problem are caused by the ff
-damaged stator
-wrong wirings of HID
i have a thread about damaged stator here
http://www.yamahat135.com/forum/viewtopic.php?p=42016
JamesCore
traxxas-modifier said:
JamesCore said:
nice mods try to lessen the pulser for more power...
nice tips bro
also lessening the pulser means what to ignition timing (advancing or retarding ignition timing) ?
advance timing.. just shave the 1/4 part of the pulser..
FIY = those who have BRT hyperand rcdi check out the manual on it it has some shared mod tips in shaving the pulser. il post some pics soon..
the doctor
better if you do lightened the flywheel also to make it balance on the other side... I did this to my bike and so far after 3k plus km of driving my sniper rocks on the accel...so easy to get a 100km speedo reading... thanks for sharing this mods...
JUNEX
balance... how about that? does the bike vibrate?
if unbalance the bearing will be unbalance and will easily broke.
Gagarinz
hello guys...
I hv some questions here...
First..
What was the effect if I didn't reduce some weight on magneto after changed and make some mod on my autoclutch (remove the autoshoes) to convert and install the aftermarket manual clutch?
Or is it better if I do make some lightening process to my magneto?
2nd..
What was the different between manual & auto model of this bike??
