Howto: Projector Retrofit Headlight
depedal
traxxas-modifier said:
use HID instead of halogen bulb.
it will reduce heat...
boss, you mean its ok to use the projector headlight with HID kit? or just the HID bulb?
goff_d_p
HID is too expensive for us poor folks, is there any other alternative? heat shield or something?
I'm still trying to figure out what way is right side up for the projector base and lens, I see in your pictures Traxx, that the black flat edge inside the lens is on top. But on the inside part of the projector, I'm not sure which side is the top?I'm going to try to figure it out today. Hope I can.
bro
i dont have projector now.
if youre really interested its order basis.
P3500 hi/low
yes its possible to use HID on projector.
just replace the stock bulb wit the HID bulb.
goff_d_p
Traxx, If I got HID, what do I need to do for installation? I keep hearing all kinds of problems from others about it draining the battery, or needing different switch.
Sonnyjha
sir traxx, pa pM nman price if ksama narin syo ung buong headligth assemble ksama na labor pakabit ng projector ung Dual beam..den pa PM po if pano ko bigay syo payment..im from laguna.. replacement nlng ksi gamit ko ngaun Headligth assembly ksi nbasag sa semplang gus2 ko sana yung orig narin from yamaha mismo P1700 d2 samin eh sana mas mura jan whehe!
jangbest
Hi guys
today i did the projector retrofit to our stock headlight.
projector lens are the best efficient headlight because it maximizes
all the brightness of the bulb giving out and directs it evenly
on the road surface.
No scattering of lights which causes glare to oncoming traffic.
if youve wonder, Highend expensive cars are using projector headlight.
So its time to convert our stock headlight to projector.
What you need is a Projector Lens.
There are two types of projector lens you can choose.
first is Single beam, which emits Low beam light only.
second type is Dual beam, which you can have High Beam or Low beam light
using switch.
the ff projector lens are using H1 type of bulbs.
In this howto,
i use the Dual Beam Projector Lens.
First is i remove the stock bulb socket at the back of the headlight
Once done, You need to remove the headlight cover lens.
from the internet they said you need to use Oven or Heat gun to heat the sticky glue
and will be able to remove the lens...
But since I dont have any oven, I dont have any Heat Gun.
ITS TIME TO USE OUR OWN MIGHTY COOKING PAN :)
Lets cook the headlight, hehehe
chef traxxas, whats our ingredients?
Ingredients:
-big bowl that headlight can be fitted.
-water
-headlight
-2 pcs small flat screw driver
first is You need to BOIL first the water.
once boiled, turn off the cooking stove.
Dip your headlight in the boiling water.
remove it in the boiling water,
remove the lens carefully by pying the lens and body using small flat screw driver.
be careful not to break the lock..
be very patient, you will feel that the sticky glue is very soft when its heat.
when the glue is soft, its easy to remove the lens
when its cold already, Dip it again in the hot water and wait for 30 seconds...
then do it again , until you can easily remove the lens
be very patient once until you finally remove the clear lens
[/img]
Once done, RESHAPE the hole so that the projector lens will fit inside the hole
here the projector lens is fitted to the headlight
This is the result
using LOW BEAM LIGHT
perfectly straight line thus you can see more road ahead BUT still wont glare oncoming traffic :)
Using HIGH BEAM LIGHT
now thats the whole road lighted :)
now my night turns into day using Projector Lens + HID xenon light
Please PM me also pice and shipping
jsmabangez
i've done boiling my headlight too! doesnt work 4 me. a bit hesitation my orig h/lyt might break or damaged. . so i bought a replacement headlight. thumbs up for this post :thumbsup:
