=X-II-AIRFORCE-ONE-II-X=
i already change my carb into keihin carb 28mm, faito cams,ignition coil, v spring, c spring. the problem is, whenever i quick rev my throttle from the idle, it seems like the power is not there. i have to rev the throttle i little bit just to feel the flaw of fuel and air right into the carb.... is this normal on big carbs? is there anything i can do to improve this problem? any help will be highly appreciated...
