i need the our master help regarding my engine prob after mo mods
i installed faito cams, keihin carb 28mm, vixion v spring, brt clutch spring, brt dualband cdi, protec ignition coil and ngk iridium sp. my question is, is it normal to hear scratching sound or somhting bumping i cant explain exactly the sound but its an annoying sound right after you reach each top speed in every gear. i cant rev it anymore because of that sound. is it normal? whats the probable cause of that annoying sound? any help will be delighting ty... help help mga masters
the mechanic told me that its from the carb since its a big carb already, so alot of air is going into well that is according to my mechanic i dont know if its true, is it possible on big carb? and he said if i bore up into 57mm or 60mm the sound will be gone. is it true?
lpsnipie_67
what cam you used? S4-EVO! and what valve clearance?
asrun kamal
i think it was may be 'valve float'......coz u say that the sound can only be heard when u reach a the top RPM in every gear....
so try to change u,r valve spring....a stiffer valve spring
may this help u .......k
