If Money Is No Problem What Cdi Is The Best To Get?
xclickclickx
if i was going to buy the most best high quality top peformance CDI what would the brand would it be?
what are you guys running? and have you tried more then just the one your running?
cheers..:thumbsup:
I only speak English.
xclickclickx
try using REXTOR racing cdi, or BRT "Bintang Racing Team" racing cdi
those 2 cdi's are being used here in Philippines.
ok then so what are the differences? i understand you can get different types of BRT cdi's but im not fimilliar which would be the best racing CDI for max performance.??
JhayBoo
Here's what I only know,
Difference with regards to mapping,rpm, "depends on what kind of model"
I haven't tried using rextor, so i really can't tell that much about the two.
Let's wait for the others...
attiado
Does this two CDI's fit with stock engine without even changing or upgrading the others etc?
SOme says, changing stock cdi to rcdi will bust the starter. Is that possible? :coffee:
xclickclickx
I ended up Getting BRT Dual Band and mounted a switch as well, i looked at the more expensive ones and he showed me it and all the settings and what not,
fully adjustable but whats the point really, i prefer being fully in control of how many Revs i do is good so no limits BRT Dual Band is perfect,
and to make sure i'm not over revving i think ill invest in a KOSO RPM unit the same as the attached file..theyre just releasing in Vietnam now. :dance:
xclickclickx
also i was pretty happy getting the dual band as when me and my father compared two yamaha exciters (his one and His mates one) , exactly the same 63mm malossi kit + TM28 carb but different CDI unit and different exhausts the only way that my dads one won was by extra revs in the end other wise they were pretty much exactly the same. just one couldnt rev as hard.
So i would definatly recommend Dual Band for those that can control themselves from over reving as there is NO REV LIMIT.
HKholic
Nice Koso unit! I need to take a visit to HCM.:thumbsup:
if money is not a problem?
-rextor programmable cdi prodrag $400
-yoshimura tmr mjn 32mm carb $1200
-malossi 63mm bore $500
-racingboy forge rim $1000
-ohlins monoshock $400
-bridgestone racing tires $300
-uma superhead $600
-good mechanic (priceless)
and many more :d
