hmmmmm...testing mode.breK TIME!!!
MAGASTUS SA TIRE E2![]()
nagbburn out ba paps? hehebreK TIME!!!
ahahahahahmmmmm...testing mode.
test for 3 daysok lang sinusukatan ng side car pang delivery....tpos na po doc sa m2r kotest for 3 days
and used it 2 weeks already hows d yellow chassis doc??
kape ako d2.haay naku make up your mind..hehehehe. id still buy the ikk clutch gear but i will not be content with the 21T gear 4 alone. if i had my choice id change also the gear 1-13/32 or 13/31 and not only the gear 4-21T.
pang deliver ng pandesal sa umaga..bili bili na kayo dyan..pootpoot.ayan nagsalita na... pls post latest update ni yellow chassis when it runs marami nag aabang doc and goodluck in tuning for its new juice![]()
trying to test ikk on 61mm cmr, big valve cms19/22, pnp, rcdi, vspring, rcoil and clutch spring.. will update you soon!
wait koto..promise..trying to test ikk on 61mm cmr, big valve cms19/22, pnp, rcdi, vspring, rcoil and clutch spring.. will update you soon!
whats the 1,2.4 gear teeth?Mga paps, alin ba mas ok na set ng tranny pag nagkabit ng clutch gear, yung 21t 4th gear lang o yung 3pc na 1,2 at 4th.
daily use at pang long ride. thanks
