docgabby
wait till a nitrous oxide kit becomes available for sniper...and there is..heheheheheStarbucks Coffee kayo jan..
next project koto..eto nlng cguro at titigil na tlaga ako sa pagmmods..haha
meron na docwait till a nitrous oxide kit becomes available for sniper...and there is..hehehehehe
yup there is.NOS system would be best in fuel injection system with all the electronic gadgetery to better modulate its use. but i would rather go with a turbo system.meron na doc![]()
definitely good side but not for stock transmission. to appreciate its intended effect. you MUST change your transmission ratio. modifying a bike is like doing a puzzle. until you complete it you wont see the picture. same with us, parts that you purchase to modify your stock bike are like puzzle pieces once you PUT THEM ALL TOGETHER, that's the only time you see the bigger picture. not chop-chop modifications. aim for the bigger picture. one mod will not make your bike better OVERALL!so in short po anu ang mas epekto ng ikk drive gear sa mc ntn mga sir is it more on good side or bad effect?anu po conclusion ntn sir in lay man terms po
closer ratio third and 4th (View attachment 14709
sir wala diyan ang faito, means not good? hehe. sige cmr na lang or shark. hehe.60mm shark, 61mm cmr, 62mm uma good![]()
you have to do your own trial and error. what the ikk gear does is it transfer power to the lower end. always start with the stock combination first 15/39 then go from there.anyone had complete the research on sprocket combination on stock tranny using ikk drive gear?
from whereyou have to do your own trial and error. what the ikk gear does is it transfer power to the lower end. always start with the stock combination first 15/39 then go from there.
i second demotionjust follow what doc gabby says trial n error from said ratio![]()
wahahahaha
