is changing the valve spring really increase bike perf
6sic6
skuter said:
6sic6 said:
sir traxx, is MTRT valve spring good????
may nakapagsabi sa akin na ok raw... pero di lang ako sure :D :roll:
ask mo si sir jefraider...hehehe
as per jefraider MTRT is 30% hardened.....
but i'm so confused.....
which one is better, the vi-xion or the MTRT valve spring...
trevor
Very nice topic and inputs...so many thinngs to learn.
RCDI + aftermartket valve spring + VIXION block will increase the speed of the bike...my question is if i will change into BIG VALVE... IS IT NECESSARY TO CHANGE THE STOCK CAMS TO RACING CAMS?
thanks
skuter
para sa akin ang vixion parang 25% hardened...
kasi diba ang stock hanggang 10,000rpm then and vixion 12,500.... so parang 25% hardened... opinion lang.hehehe
@6sic
no idea about mtrt so i cant comment on it.
to know the performance of a valvespring
do the ff
-using digital tacho, get the maximum rpm before it floats on 1st gear
-it was used for more than a year without a single breakage
remember that valvespring is one of the most crucial part of the head.
failure of valvespring like breakage will mean destruction
to your cylinder head, block, valves etc...
for me vixion valvespring im very satisfied, tried and tested for long rides and abusive driver :D ride it and abuse it hehehe
lospeeder
traxxas-modifier said:
@6sic
do the ff
+100
BHER
using vixion valve spring and brt hyperband
nag test ako kanina, in 2nd gear and 3rd gear it reached 11,000 rpm.
all do kaya sya sa 12,000rpm di ko na pinaabot, ayaw ko marinig ung kkkrrrggg
:oops: :oops:
BHER
i forgot to say sit traxx. im using 15x42 sprocket combination.
ill make another test using stock combination sprocket 15x39.
i will try to reached it to 12,000 rpm in 2nd or 3rd gear:twisted:
(i hope my engine will not kkkrrrggg)
sniperyaz
AFAIK, yes if put RCDI, the purpose of the racing valve spring is to prevent the valve floating,,, because RCDI has a high rpm compare to our stock cdi,, the more rpm the more valve playing so more stress to your valve it must have a strong valve spring to prevent the stress of your valve to float, the valve spring has a recommendable cdi vise versa, the more rpm range the more strong of your valve spring but our valve has a limit too how hard valve spring the valve can :roll: nosebleed :(
