MickO_HCMC
How much extra power will I get if I up grade to bigger carburetor?
Current spec of bike below:
Just wondering if getting a bigger carbie will give me more power? guess it will? but how much?
Yamaha Exciter (T135 in Vietnam) 183cc
UMA Racing super-head (sport) 23mm inlet/20mm exhaust
UMA Racing cam 63mm Malossi bore kit
Stroke 58.7mm(Standard)
Malossi Electric coolant pump
28mm PWK carb (Thinking of fitting PWK-33mm or 35mm)
UMA Racing coil and lead
Brisk Racing spark plug AR10ZS
Shorai Lithium Ion battery
Pod air filter
Stainless header pipe (with modified standard muffler approx. 33mm end bore)
Oil cooler (KTL Tecnic)
Stainless steel oil filter (FLO)
Racing clutch 6 springs
UMA Racing / IMC RCDI
Transmission Standard 5 speed (Thinking of fitting CMS Racing 6 speed)
15F/41R sprockets (Hoddaka)
Chain (428 VX DID)
Standard front forks (Black from GP)
295mm front disk (RB) with standard caliper
Standard swing arm
RPM rear mono shock (rebound adjust)
std. rear disk and caliper
Tires F; 70/90 R; 100/80 Michelin Pilot Street
Pod air filter
Chain (428 VX DID)
Standard swing arm
