just to answer your question. it is possible to put an aftermarket cams in our stock bore.. the answer is Yes.. I believe a lot of T135 owner have done this to their machine. I myself is one of those people. the best brand?? i'm not sure about the brand but it solely depends on you, what is your preference.. what i mean is, there are camshaft that offers good acceleration, there are cams that have good mid range and top end power. a cams that have good acceleration is mainly used for racing the other one is for touring, this is just my understanding...what brand is the best in performance???
theres anything to do after u put the cams or simply a plug and play???
hows the sound if u put a cams it is loud like tiktitktitk sounds????
I'm also looking for the best cams heheh. let's wait for the masters and see what they have to say..Thanks for the info bro. Now I know where to start in choosing a good camshaft...Have a look through this forum we have been discussing Camshafts lately
http://www.yamahat135.com/threads/185cc-63mm-malossi.12941/page-3
also the tik tik tik sound is your valve clearance try 0.010mm and 0.015mm you can try what people think are the racing setting but it will be noisier and you probably won't notice any difference,
Some camshafts may come with a prime valve clearance to suit the camshaft.
Wanna try CMS Cam... Balanced power curve...Thanks for the info bro. Now I know where to start in choosing a good camshaft...
bro ang cms cam b meron ba decompression pin? if to be match with vixion bore kit ..do i need to valve pocket my piston? TIAWanna try CMS Cam... Balanced power curve...![]()
CMS cams has no decompression pin slot but its match to vixion bore kit bcoz of stage 2 category of camshaft...yes you need to valve pocket the piston deck to avoid future problemsbro ang cms cam b meron ba decompression pin? if to be match with vixion bore kit ..do i need to valve pocket my piston? TIA
sir naka vixion cams ako sa stock bore and my mj is 22.5n pj is 107 open pipe.bakit po nagkakaron ng backfire ????help nmn poCMS cams has no decompression pin slot but its match to vixion bore kit bcoz of stage 2 category of camshaft...yes you need to valve pocket the piston deck to avoid future problems![]()
if theirs a fire change your jettings but if sound only tune your carb...sir naka vixion cams ako sa stock bore and my mj is 22.5n pj is 107 open pipe.bakit po nagkakaron ng backfire ????help nmn po
oh.. so CMS cam has a high lift that requires your piston deck to be pocketed..CMS cams has no decompression pin slot but its match to vixion bore kit bcoz of stage 2 category of camshaft...yes you need to valve pocket the piston deck to avoid future problems![]()
Higher lift gives better performance.. so CMS gives better performance..
If you have back fire during engine break, probably you are lean.. try to close a little bit your air screw.. Do you use your stock carb? Try to check also your carb diaphragm and make sure all your screws and connection are tightly secured and no air leak..sir naka vixion cams ako sa stock bore and my mj is 22.5n pj is 107 open pipe.bakit po nagkakaron ng backfire ????help nmn po
tnx for the answer bro how about vixion cam? do i nid to valve pocket if match with vixion bore kit and vixion vs?does it hv decomp pin?CMS cams has no decompression pin slot but its match to vixion bore kit bcoz of stage 2 category of camshaft...yes you need to valve pocket the piston deck to avoid future problems![]()
vixion cam is stage1 camshaft...no need valve pocket but you need to adjust ung valve tappet clearance...or much better do a valve pocketing on piston deck for your own safety...tnx for the answer bro how about vixion cam? do i nid to valve pocket if match with vixion bore kit and vixion vs?does it hv decomp pin?
Higher lift camshaft doesn't mean better performance on your mc still it depends on duration of cams and the settings of the bike especially it depends on the mechanic...IMHO to suit or to boost the better performance of your bore up kit you need to upgrade your stage of camshaft based on Lift & Duration...Most of TEAM GSD & Other T135 Lover here in Philippines used CMS camshaft same profile with YYPANG Camshaft & IKK Camshaft also in UMA casmhaft...the performance of your bike is depends on the mechanic and how he works on your engine...oh.. so CMS cam has a high lift that requires your piston deck to be pocketed..Higher lift gives better performance.. so CMS gives better performance..
the new version of kawahara k1 "Black Mamba" (stage 1) has decompression pin...you can plug and go but don't forget to adjust your tappet clearance b'coz of additional lift...for safer you need to valve pocket so no tiktik soundi have a question about kawahara black cams, just to clarify if it has decompression pin and if it would not need the piston deck to be pocketed?
sound like stock
Thanks for the clarification bro..Higher lift camshaft doesn't mean better performance on your mc still it depends on duration of cams and the settings of the bike especially it depends on the mechanic...IMHO to suit or to boost the better performance of your bore up kit you need to upgrade your stage of camshaft based on Lift & Duration...Most of TEAM GSD & Other T135 Lover here in Philippines used CMS camshaft same profile with YYPANG Camshaft & IKK Camshaft also in UMA casmhaft...the performance of your bike is depends on the mechanic and how he works on your engine...
my carb is intack my problem is back fire and my valve tappet is tignten fast what is ur advise my fellow sniper owner!!!???oh.. so CMS cam has a high lift that requires your piston deck to be pocketed..Higher lift gives better performance.. so CMS gives better performance..
But if you have back fire while you're gaining RPM, I think it's another story.. right guys?![]()
What is you valve tappet clearance? Try to richen your a little bit your A/F mixture,, slightly close the air screw then test.. make sure also that you secured your pipe connection, no air leak.. Try also to replace your exhaust gasket, I think it's only 50php..my carb is intack my problem is back fire and my valve tappet is tignten fast what is ur advise my fellow sniper owner!!!???
What is you valve tappet clearance? Try to richen your a little bit your A/F mixture,, slightly close the air screw then test.. make sure also that you secured your pipe connection, no air leak.. Try also to replace your exhaust gasket, I think it's only 50php..[/qu
i already check all connection including exchaust gasket there is no problem there. later i adjust my a/f mixture. my valve clearance is .10. 15 what is other cause of very fast tighten of my valve tappet???!!!!
