Sir Hi Speed Valve Set... Magkano... Need ko kc.... Pa PM....![]()
BRT Powermax CDI for Sniper & Sniper MX
- Dual Band
- Hyperband
NOB1 Tribold Series Pipe from Indonesia for Classic & Sniper MX
- chrome elbow
- black canister
- comes with DB Killer (Silencer)
- bracket
- 2pcs. Spring
- plastic protector
- FREE! Cap
CMS Racing Products
- CMS Racing Camshaft
- CMS Racing Gear Set
1ST - 31T
2ND - 29T
4TH - 21T
- CMS Big Valves 22/19
- CMS Valve Spring (H)
FAITO Products for Sniper (All Faito Products Price are NEGO)
- Racing Gear Set (Tranny Set) = 10,000
- Crankshaft 3.5mm Jack up = 8,500
- Faito Infinity Block 60mm kit = 3,800
- Turbo Camshaft = 2,800
- S4-Evo Camshaft = 2,200
- Ignition Coil 7400 = 1,750
- Clutch Spring Zero = 650
- Engine Valve Set = 1,800
- Racing Clutch Carrier Bushing = 250
- Racing Engine Bearing set = 1,800
- Clutch Plate Thunder (2010) = 2,400
- Clutch Plate Swift-Z (2010) = 950
- Racing Disc Break Pad GOLD (2piston) = 1,200
- Racing Disc Break Pad PLATINUM (2piston) = 2,000
- Faito Plug wire (HTW) = 750
- 21T 4th gear = 1,800
- Stock Connecting Rod Set = 2,600
- Gear Set 1st,2nd & 4th = 3,600
SKF Bearings
- 6300 P350.00
- 6301 P350.00
- 6004 P350.00
COMBIZ Mono Shock for Sniper
- solid built
- smooth response
- made in Thailand
7 Speed Front Fork Housing
R9 Monza for SniperMX
Sniper Hub for Spoke Rimset P1,950 set
Protec Racing Coil (Ultimate & Carspeed Edition)
Hi Speed 22/24 Big Valve for Sniper & 22/24.5 for Raider
Hi Speed Valve Springs for Sniper & Raider
Kiehen PE 28mm roundslide carb (OEM Honda Thailand)
Genuine Mikuni VM 26mm Carb (Thailand)
OKO Carb 28mm
Vixion Valve Springs SALE!!!
1 set na lang.
P1,600 FREE SHIPPING
Vixion Kit Complete Set SALE!!!
2 kits available
-cylinder block
-piston pin
-piston ring
-piston
-gaskets
P5,450 FREE SHIPPING!!!
Call or Text @ 0923-9498051 (my new contact no.)![]()
jvalzkie@gmail.com![]()
No bogus buyer and be sure you know the parts that you are buying for.
Seller is located at Surallah, South Cotabato
Can ship the item anywhere in the Philippines
TY Sir... Ok lang ba yan sa Stock Block 54mm...... Preparation ko kc yan sa 62mm UMA eh... pero inona ko muna kc bumigay na eh......hi speed valve 22/24.5 na lang available P2,800
NOB1 PIPE is COMING TO TOWN!![]()
mmertmmmayhhhhmeron pa vixion ki?NOB1 PIPE is COMING TO TOWN!![]()
