ygpmSory doble doble post ko sira ata net eh
how much highspeed piston??![]()
X-Ray 62mm Bore Kit Set Complete
R9 Mugello for SMX & Classic Sniper
Pitsbike Nikasil 62mm Bore Kit Set Complete
FAITO Products
RB Titanium Ver. 1 Fork Stabilizer
Nob1 Pipe Complete Set (black canister with hard chrome elbow and db killer)
Hi Speed Stage 1 & 2 for Sniper Classic Made in Thailand
60mm, 61mm & 62mm Hi Speed Piston for Sniper Made in Thailand
Faito Mini H.I.D. Bulb
text me @ 0923-9498-051![]()
BRT Powermax CDI for Sniper & Sniper MX
- Dual Band
- Hyperband
NOB1 Tribold Series Pipe from Indonesia for Classic & Sniper MX
- chrome elbow
- black canister
- comes with DB Killer (Silencer)
- bracket
- 2pcs. Spring
- plastic protector
- FREE! Cap
CMS Racing Products
- CMS Racing Camshaft
- CMS Racing Gear Set
1ST - 31T
2ND - 29T
4TH - 21T
- CMS Big Valves 22/19
- CMS Valve Spring (H)
FAITO Products for Sniper
- Racing Gear Set (Tranny Set) = 10,000
- Crankshaft 3.5mm Jack up = 8,500
- Faito Infinity Block 60mm kit = 3,800
- Turbo Camshaft = 2,800
- S4-Evo Camshaft = 2,200
- Ignition Coil 7400 = 1,750
- Clutch Spring Zero = 650
- Engine Valve Set = 1,800
- Racing Clutch Carrier Bushing = 250
- Racing Engine Bearing set = 1,800
- Clutch Plate Thunder (2010) = 2,400
- Clutch Plate Swift-Z (2010) = 950
- Racing Disc Break Pad GOLD (2piston) = 1,200
- Racing Disc Break Pad PLATINUM (2piston) = 2,000
- Faito Plug wire (HTW) = 750
- 21T 4th gear = 1,800
- Stock Connecting Rod Set = 2,600
- Gear Set 1st,2nd & 4th = 3,600
SKF Bearings
- 6300 P350.00
- 6301 P350.00
- 6004 P350.00
COMBIZ Mono Shock for Sniper
- solid built
- smooth response
- made in Thailand
7 Speed Front Fork Housing
R9 Monza for SniperMX
57mm Vixion Kit for Sniper
- block
- piston
- rings
- gasket
Sniper Hub for Spoke Rimset
*PM or Text me @ 09157099333
No bogus buyer and be sure you know the parts that you are buying for.
Seller is located at Surallah, South Cotabato
Can ship the item anywhere in the Philippines
My FB Account:
jvalzkie@gmail.com
- Dual Band
- Hyperband
- chrome elbow
- black canister
- bracket
- 2pcs. Spring
- plastic protector
- FREE! Cap
CMS Racing Products
1ST - 31T
2ND - 29T
4TH - 21T
SKF Bearings
- 6300 P350.00
- 6301 P350.00
- 6004 P350.00
- solid built
- smooth response
- made in Thailand
- block
- piston
- rings
- gasket
bro ung combiz mono shock magkanu? free shipping ba?
wala ako nyan try pm kr.r.sniperpa pm poh cms cam...salamat sir..![]()
haha ni like ba naman. wala po bro. try mo kay kr.rsniperSir meron pa kayo available na cms big valves? pa pm po ng price. sure buyer po.
