icemanx1r6
Any update for the price of the above subject?
guys, below is a rough computation on your compression ratio considering there are no changes in the head (Shaving, jackup, high comp piston and polishing). Porting doesn't increase compression.
Stock LC135
Combustion Chamber Volume = 134.4cc/10.9(Compression Ratio)
= 12.33cc
Vixion Kit Compression (57mm piston dia)
= 149.78cc/12.33cc
= 12.14 Compression Ratio
91Octane above recommended
62mm kit = 177.2 cc/12.33cc
= 14.37 Compression Ratio
95octane rating recommended. Po
65mm kit = 194.78cc/12.33cc
=15.80 Compression Ratio
(Big Head upgrade, or polishing is not recommended but a must to prevent knocking) Polishing increases the head volume.
Compression ratio 2:1 3:1 5:1 10:1 15:1 20:1 25:1 35:1
Pressure ratio 2.64:1 4.66:1 9.52:1 25.12:1 44.31:1 66.29:1 90.60:1 145.11:1
Question lng mga bro, is the valve for sniper classic is the same for sniper mx? Tia
