or else kadyot kadyot kah ng gulong sa likod..hahadapat malaki tiwala mo sa wiring at batery mo pag niremove mo ung kickstart.. or else...........
dat's wat dey kold "RESING PAIKOT"or else kadyot kadyot kah ng gulong sa likod..haha
this is what you called "the professional advice"yung makina ko dati sniper, tinangal ko ang kickstarter assembly (whole assy kasama inside sa crankcase)
the reason is , meron rotating mechanism ang kickstarter assembly which causes additional rotational weight and friction.
in my case, kickstarter is useless so tinagal ko na lang para additional performance sa motor ko
if you dont use kickstarter, i suggest to remove the whole kickstarter assy..
amen to dat..this is what you called "the professional advice"
picture please...oh .galing .salamat po sainu. kasi my nakuha akong sniper.. wala po syang kickstarter. curious lang. sa icip ko bka nagalaw makina .. haha. noobs lang po
