Koso Digital Problems In My Sniper 135
MightyThor
patulong naman mga sir. yung koso digital ko kasi sa sniper classic madalas nag rereset and nag blink naman minsan tapos yung needle tagal bumalik humihinto sa dulo then matagal bago bumaba.
patulong naman mga sir. yung koso digital ko kasi sa sniper classic madalas nag rereset and nag blink naman minsan tapos yung needle tagal bumalik humihinto sa dulo then matagal bago bumaba.[/QUOTE
re check your wiring system maybe you forgot something or manual of koso
sniper135lc
from where you live bro?
i think you have a wrong tapping of wire for the supply.
Gie
yung red wire sir dapat naka direct po sa ignition switch socket papuntang battery for (standby power) para sa clock para di narereset.. magiging normal din po ang galaw ng needle nung taco mo kapag naayos mo na yung wiring.. hope it helps..
sniper135lc
i think koso has a plug and play socket for the ignition switch. you have to attached it on the stock socket of the ignition. and i believe the main socket has already for the clock which is the power will not be interrupted when you turn off the switch since you already attached the adaptor system on the ignition switch. kindly check the manual of koso there was some two wrong wiring in there which is the turn signal light and the rpm wiring need to be swapped.
