KOSO DIGITAL SPEEDO and Voltage
Hi guys
just a survey on Koso digital speedo users.
id like to know what voltage reading in your koso speedometer in the ff
-battery standby voltage (engine not running)
-voltage at idle (engine running)
-voltage at 5000rpm
-voltage at 7000rpm
i just want to compare voltage readings
thanks
peakabu
12.3v engine not running
12.7v idle
15.8v @ 5k rpm in center stand mode
15.8v @ 7k rpm in center stand mode
dennis_808
Bro, reading nng koso speedo is 1 volt higher compared to a handheld voltage tester. Nkapagtry na ko 2 tester same reading sila at 13 volts vs koso speedo reading at 14 at 3000 rpm. Dunno bout others kung ganun din sila.
4f7erx
Hi guys
-voltage at 5000rpm
-voltage at 7000rpm
thanks
bro traxx
here's mine
-battery standby volt 12.4v
-voltage (idle engine running) 14v
-voltage @ 5k rpm 15.3v
-voltage @ 7-9k rpm 16.3v
-with park light ON
koreano
bro traxx
here's mine
-with park light ON
Gud pm bro,,,where did you bought your Digital Speedo & how much???tnx.....;)
bloolink
Hi guys
-voltage at 5000rpm
-voltage at 7000rpm
thanks
pag full charge ang batt
12.7 on on
13.5 idle
13.5 5k rpm
12.1 v all running light on( HID, park light, signal light brake light, and miscellaneous lights)
