skuter
ehem... meron pa ako.... pm nalang kitablueblink182 said:hello po!mga paps ask lang po kung magkano? and san makabili?
same problem on signal lights but fixed upon installation by sir einver. gps setting was set at 100 percent. quite accurate, gauged on a raider r150. connected the rpm on orange wire. better reading than in the white wire. I think the orange wire is same on the wire connected on the coil since they have same color. dunno if the same on other bikes. regarding the temp sensor, .....SECRET! hehehehaen said:@traxx : i connect it to the white wire (pulser) and the result is just what the video shows, erratic behaviour.. its not a connection problem since i've already hardwired it..
anomalies i've found :
1. that orange wire gives more accurate signal (i asked mr. Vincent Tsai from KOSO TAIWAN about this and he suggests the same thing IF the WHITE WIRE doesnt work)
2. The turn signal light got reversed incorrectly in our wiring harness e.g : Left became Right and vice versa. Did u Sniper users got this kind of problem too ?
3. Regarding the GPS measurement, so far mine on 80/90 - 17 got it correctly on 103% compared with two GPSs same as yours traxx
N82
and
iGO GPS
if i set it on 100% i got slower about 3-4 km/h compared to GPS.
4. THE MOST ANNOYING is the bolt size of the temp sensor, why they give big size compared to 10 mm plug on the oil and water check bolts on the cyl head and block.. this requires us to get additional accessories from KOSO like that Water Temp Sensor Adaptor.
in the CDI connector theres 2 almost confusing colorshaen said:@traxx : i connect it to the white wire (pulser) and the result is just what the video shows, erratic behaviour.. its not a connection problem since i've already hardwired it..
N82
and
iGO GPS
okay, i dunno what happens, but seems this rpm reading problem can be found on other speedo as well like RX series.. regarding the 'snow white' cabletraxxas-modifier said:in the CDI connector theres 2 almost confusing colorshaen said:@traxx : i connect it to the white wire (pulser) and the result is just what the video shows, erratic behaviour.. its not a connection problem since i've already hardwired it..
N82
and
iGO GPS
-WHITE
-WHITE YELLOW
the first time i open the wire covers i thought its white
but when i take a closer look and inspect, it has a very little
yellow line almost removed.
try to double check.. it might be white yellow that you tried..
so far in me, i spliced the WHITE, soldered the rpm wiresensor to
it and got no rpm problem whatsoever.
anyway if orange works, thats fine.
the white wire might be a little more accurate as its direct from stator pulser.
for gps:
90/80 = 90mm x 0.8= 72mm height
80/90 = 80mm x 0.9 = 72mm height
whats your front mags width you are using bro?
i have 2.15 front mags width, that might be the reason
of the difference of our circum settings.
the stock front mags 1.6 with 70/90 have 9% advanced to gps speed.
see this video http://www.youtube.com/watch?v=-4LeXpQoA6s
wider mags and narrow mags will make the circumference differs a bit.
for signal turn, yahh exchange the brown wire and green wire.
i have A/F sensor here from my other gadget it might work
with kosometer im not sure yet if kosos af is narrow band or wideband
... i even parallel it directly to the stator pulser socket near the starter motor to see whether i made a mistake.. and the result is still the same.. while my previous tachometer works fine with the pulser cable.. if you got it working well with the snow white cable
i'm glad u did.. orange wire is much accurate rather than the white wire cable.traxxas-modifier said:did you connect rpm in orange wire?
the manual says the rpm must be connected to the WHITE (pulser) wire in cdi.
whats the purpose of orange wire?
TIPS:
instead of using the midway connector for rpm.
its better to directly solder it in the white wire.
why?
because theres a chance that midway connector
will cut 1 or 2 strands of your white wire
when you use it. as times goes by if you remove
or moved the cables, it will flex and cut again additional wires.
or it will not connect correctly if its pressed lightly
thus providing inaccurate rpm.
i do suggest to solder it directly the rpm sensor wire to white wire.
thats what i did and runs perfectly!
@haen
ive done GPS testing with koso.
GPS TIRE CIRCUMFERENCE SETTING: 100%
FRONT TIRE: 90/80x17
Readings:
Koso speed: 137 kph
GPS Nokia N82: 133.2 kph
GPS Holux M1000: 135 kph
so a 90/80x17 tire front and
100% setting tire circuference on koso meter
will have 2% advanced inaccurate to REAL GPS SPEED
Heres a sample of the koso meter in action using tire circumference of 100% on 90/80 tire
[flash width=480 height=385]http://www.youtube.com/v/mxX3QYTTGW8&hl=en_US&fs=1[/flash]
FOR ACCURATE GPS SPEED :
use the ff setting:
90/80x17 front tire= KOSO TIRE CIRCUMFERENCE 98%
mine i set tire circumference to 100%
nice! 8)BHER135 said:
For Oil TempVoldedore said:Hi, can you help me about the temp sensor ?
Where can i connect it to my bike? T135 too.
It's a PT 1/8 temp sensor, it say "installed in the oil release hole"
I dont know where is that hole( If you can, show me some pic.
Really thanks !
hahahaha mao jud!kayode said:thanks idol chiglai for the tip on how to install my temp gauge.. ok ang style kol!!!
@harold / skuter
i know where that 1 piece went... he is overJOYed right now.. haha!
