LC Middle panel hole
ghostz32
just as we know..in the middles of the bike,we've found that there's a hole and the underneath is the carb..
correct me if i'm wrong..whats really is the function of that hole..if its for the purposes of air flow,
what will happen during rainy day..permanetly the water will jump inside,through the engine or carb itself..
does the water will effect the carb performance...if yes,how can we prevent it..any solution..???
unlimited express
well, its actually for ventilation purposes. I think its ok even water comes in coz the carb is sealed and the air filter have a hard plastic cover and the hole is facing down so the water will not go inside.
goff_d_p
thats right, the water, won't affect the carb unless your using a presser washer. or a jet setting on your hose sprayer. the carb for the most part have no openings for water to get in. so it shouldn't get wet inside. the main holes in that center panel are for air flow to the filter. which is also a sealed system except for the flow vent.
Mas Catoer
I dont quite get it. But most of carb have that.
There are two that have no direct effect to engine.
First one to remove gas sedimentation -> has screw on it.
Second to remove gasoline overflow. so the gas level in carb is kept on steady level.
Hope that right :) :)
rudduan
that holes even helped to reduce heat from engine,i mean not so much,but a little help does make some effect rite???
