MGA ADIK SA MODS DITO NA TAYO PATI MGA BAGO PA LANG NAAADIK
kr.r_sniper
Clutch Gear Assy
1. IKK Clutch Gear 22T-72T
RACING CDI
1. BRT dual band
2. Rextor v3
3.BRT hyperband
4. BRT Super i-Max
5. TDR
6. IKK
7. Varro (Thailand)
RACING CAMSHAFT
1. YY pang cams 5.8
2. Pan asean cams 6.5
3. FAITO S4 Evo stage 1
4 .FAITO TURBO CAMS 5.8
5. Kawahara k2 Cams 5.8
6. CMS 5.8
7. LHK Cams
8. NCY Custom Cam Profile
9. HISPEED Cams 6.2 & 6.5 lift
10. Custom Grind Cams from CAMPROFILE / Yolac Racing
11. STOCK PROFILED BY CAMPROFILE
12. Kawahara K1 Stage 1
13. IKK stage 2 5.8
14. UMA Stage 2 5.8
RACING VALVE SPRING
1. YY pang valve spring
2. Vixion Valve spring
3. TK Valve Spring
4. Kitti Valve Spring
5. HISPEED Special Valve Spring for Spark135
6. APPI R-specs (14,000 rpm)
7. CMS Valve Spring (H) (13,000)
RACING CLUTCH SPRING
1. CRG clutch spring
2. YY pang clutch spring
3. LHK clutch spring
4. FAITO
5. TK Clutch Spring
6. Kitti Clutch Spring
7. SYS 6spring Clutch Housing
8. BRT
RACING CLUTCH LINING
1. FCCI Clutch Lining for Honda Wave 125 (orange)
2. Faito Swift-Z
3. Faito Thunder
BIG CARB
1. 28mm keihin thailand round slide
2. Keihin Japan PE27
3. Keihin Thailand PWK28 (flatslide)
4. Mikuni TM28 SUDCO (for racing use)
5. Yoshimura MJN TM26
6. OkO 26/28/30mm
7. UMA 26/28/30mm
8. WABRON 30MM WITH ACCELARATOR PUMP
9. TM28
10. VM26
11. UMA24,28,30,32,34
BORE UP KIT
1. Vixion block diasil 57mm
2. faito 60mm block
3. Shark 62mm Block
4. CMR 61MM
5. UMA 62mm ceramic
6. JVT 62mm ceramic
7. Hispeed 62mm Ceramic
CYLINDER HEAD (WITH BIGGER VALVES)
1. HISPEED Cylinder Head for LC135 22:24 / 20:22 Valve
2. CMS 19/22
3. LHK 19/22
4. TK 18/22
5. APPI 19/22
6. CUSTOM MADE 20/23...21/23...21/24
IGNITION COIL
1. Racing Coil API
2.namban
3. ULTIMATE RACING COIL
4. ProTec Groundstrap
5. API Ignition Coil
6. PROTEC GROUNDSTRAP WITH CURRENT STABILIZER
7. Faito Racing Ignition Coil
8. Pro-tec Carspeed
SPARK PLUG
1. Splitfire
2.iridium denso
3.Iridium NGK IU24
4. NGK PLATINUM
5. MAGNUM Iridium
PIPES
1. AHM gold
2. YY pang Shorty big elbow
3. YYpang Longy big Elbow
4. NOB1
5. NamBan Circuit Spec
6. NamBan Open Spec w/ bigger elbow and longer canister
7. HISPEED Open Sec for Spark135
8. 4N
9. ECS
10. HGM
11. JAD RACING
12. CLD
13. AHM SPORT SERIES
14. AHM TRI OVAL
15. AHM CF (carbon fiber)
16. DBS
17. GRC pipe
18. R9 Mugello NG or New Monza
19. Yoshimura
20. AHRS
21. AHAU
22. CJ Ipoh
Sprocket & Chain Set
1. SSS
2. PKM
3. RK
4. Faito
5. Sinnob
UP FOR TODAY
UP KO LANG :D
Mono
ahahahaha =)) akala ko ba last na un :D si NOI-NOI :p
2,500 :D exclude shipping
anu ba dyan?! Pro-tec Ultimate ba With Ground Strap? 2,100 ksama shipping :D
nako..wag naman ngayun..gipit pa paps.. yung pics lang nung Pm ko ang view ko .hehe :D
Viejay17
mga paps im looking for yypang big belbow pipe for sniper or musashi.. anu po ba ok na pipe? thanks! cnu jan nagbebenta eto number ko 09065397904! salamat!!
