rich_havens
Dagupan st. or Dagupan pangasinan?
nyek... malayo pala... pero nakarating ka ng fast lane at cyclone?
un ang dpat mtest ni ronnel sakin kung normal parin ang pagfunction ng regulator ko. ndi pwedeng long ride tong motor ko pagganito..[/quote:3mm9l7k0]ronnelmarc_21 said:Sidro said:[quote="the_one":3mm9l7k0]kahit patay HID ko umiinit parin pero minsan ndi nman sya umiinit. ronnel already checked my charging w/c is normal 13V lng ung kuryente ko. need lng tlga siguro ng major wiring checkup pra malaman kung san nagmumula ung paginit ng batt ko..Sidro said:[quote="the_one":3mm9l7k0]1. kung nagalis k ng decomp malamang dahil don or defective estarter.sniperCJ said:ako naman, diko alam kung saan nagsimula..takte..
* e-start not functioning well, diko alam kung bakit e..pag sinusubukan ko parang ang hina ng e-start ko, bumabalik sa pag check fan ang bike ko..diko alam kung wirings o batt ko..pero wala naman ginalaw sa mga wirings ko..hay..
* yung batt ko, kung diko pa napansin..halos wala na palang tubig..nagulat ako, kase diko naman ginagalaw yun..at parang naging luma yung batt ko sa dami ng damage ng mga takip, parang kinahoy o pinalitan yung batt ko..hay..
* naging mausok bike ko..diko alam kung bakit, simula nung kinabit rvalve springs ko![]()
2. regular check tlga dpat pag de_tubig ang batt mo. i suggest magmaintence free k n batt.
3. MAUSOK = replace piston ring = check valve clearance = nasobrahan s langis
paps #4 problem mo, kpag nka sindi yung HID mo? umiinit parin ba?.. Nag palit ka na ba ng regulator?.Sidro said:[quote="the_one":3mm9l7k0]ok so much disappointed on my HID, since i installed this super liwanag headlight i encounter the following
problems:
1. low batt
2. wiring problems
3. grounded wires
4. super hot batt (over charge??)
5. e-start grounded wen wet
solutions:
1. low batt > solved, change to 5amp batt
2. wiring problems > solved, rewired by ronnelmarc
3. grounded wires > solved, rewired by ronnelmarc
4. super hot batt (over charge??) > still my current problem
5. e-start grounded wen wet > still my current problem
hopefully someone can solve my #4 disappointment
natanong ko lang kasi meron kami inaayos na mga UPS dito ang gamit for storing energy is small battery like to ours MC'c. And meron ako naayos dito na umiinit sya kung walang load, then figure out ko na sira yung regulator, trial and error ginawa ko. I mean pinalitan ko sya agad regulator. ayun ok na sya so far, hindi na umiinit.
Then yung isang umiinit din, kahit may load umiinit pa din as in hindi normal yung pag init nila... nag palit ulit me regulator, ayun ok na rin.
Hindi ko lang alam kung itong mga problem na na solve nmin dito kung may ralation sa MC's natin, kung titingnan kasi yung battery halos wala pinag iba sa battery ng motmot natin. all with the same specs..
trade mo nlng s kaha ko hehehe..naigrace said:my modification disappointments is the paint job![]()
ang dali ko lang nagsawa.
- depende lng cguro sa mekaniko yan paps..yung HID ko, 2 1/2yrs na, ke cyclone ikinabit..ok nman..never ako nagkaprob..BHER135 said:@ronnelmarc, thanks a lot pafs
CYCLONE, FASTLINE sa caloocan pinaayos ko d nila nagawa eh.
- ganun? agad2x? palit tyo motor paps.. pwede na rin kaha lng! hehehe..naigrace said:my modification disappointments is the paint job![]()
- balik mo paps, may warranty nman HID installation nila..BHER135 said:nakakahindang na pag d alam ang solusyon sa problema sa motor.. i hope wiring l;ng ang problema.
perhaps i can recommend you to see a doctor for your MC to check it sir and i can recommend sir paul garcia of lighthouse zabarte... me and ryioki1 knows him...rich_havens said:[quote="the_one":1g7axj8c]ok so much disappointed on my HID, since i installed this super liwanag headlight i encounter the following
problems:
1. low batt
2. wiring problems
3. grounded wires
solutions:
never ko namang pinagsisihan yung HID ko kasi gawang XIATGLASS eh. lahat kame sa team impakto halos naka HID at si xiatglass lahat may gawa wala namang nagrereklamo ng lowbatt.BHER135 said:yes pafs pangasinan,tarlac location ko marami na beses ako punta dyn, 3 tyms ko na pinagawa HID ko caloocan..
pafs O.T na tyo.. sensya na po
traxxas-modifier said:sniperCJ said:ako naman, diko alam kung saan nagsimula..takte..
thats the cause of lowbattery/ battery malfunction.sniperCJ said:* e-start not functioning well, diko alam kung bakit e..pag sinusubukan ko parang ang hina ng e-start ko, bumabalik sa pag check fan ang bike ko..diko alam kung wirings o batt ko..pero wala naman ginalaw sa mga wirings ko..hay..
if you check the battery by voltmeter, its 12volts and looks ok
pero kapag estart mo, magiging 9volts lang yan or below
and that causes the check fan and wont start.
try to use only kickstart, and that will start without a problem.
solution: change battery to a new one.
BATTERY IS VERY IMPORTANT in our bike (due to our bike is using dc battery drive cdi).sniperCJ said:* yung batt ko, kung diko pa napansin..halos wala na palang tubig..nagulat ako, kase diko naman ginagalaw yun..at parang naging luma yung batt ko sa dami ng damage ng mga takip, parang kinahoy o pinalitan yung batt ko..hay..
malfunction battery/ low voltage battery will give a bad performance to our bike.
voltage of battery under full load should be more than 12.5volts
else your bike wont give the best performance.
mausok is caused bysniperCJ said:* naging mausok bike ko..diko alam kung bakit, simula nung kinabit rvalve springs ko![]()
-scratched block
-piston ring
-valve seal leaking (rubber seal of intake/exhaust valve) Most probably
-rich mixture in carb(if stock carb, walang ginalaw sa carb, remove the airfilter it might be clogged)
mine i experienced mausok during acceleration,
the culprit is RICH jet needle of my 26mm carb,
when i adjusted to a leaner setting, it works ok no smoke na.
ano ba decals mo sa likod?JamesCore said:uu walang sita..nasubukan ko kagabi sa chekpoint.. pinara ako pagtabi ko ang sabi ng mga PO's bakit po wala kayong headlight? sabi ko: kasi sir may chekpoint at mataas yung tutok ng headlight ko nkakasilaw sa kasalubong.. ganun ba? sabay tingin sa plaka.. nakita yung decals ko sa likod.. sabi ng Pulis cge hepe busina ka nga.. sabay busina tapos sinabihan ok.. sige KARGA. meaning alis..hehehe ayus yung bulb ni jchris dami nagtatanong sakin kung meron pa nun ahahahaha
