MRTT valve spring feedbacks..
aklan
mga sir ask ko lang kong ok po ba ang valve spring nang mtrt bibilhin ko apalng kase kasama s4 evo cam sa sniper ko po na stock ikakabit please advice......:cool:
Paladin
S4 evo and MTRT valve spring user here. No problem with it's combination. Just make valve pocket on the piston and meticulous tappet setting to be safe.
aklan
mrs. faito guy sell it to me and i don't have any idea about the result sir.
can you give me some advice thank u
Paladin
The result of Faito S4 evo cams is you will have a higher engine compression. Therefore you'll attain more speed. MTRT valve spring is needed to avoid valve float. This will prevent your valves to hit the piston on high RPM.
aklan
sir thank you for your advice. i am so excited for the result sir thank thankyou
aklan
sir for the sprocket isn't ok to use 13t front rear and 34t?
for my tire i use 70 in front 80 in the back,
aklan
im using MTRT valve spring so far so good 13,000rpm, just plug n play no need to cutting required...
i don,t understand ur mechanic....
s
mga sir ok naman po ang mtrt valve spring,,gamit namin lahat yan dito sa grupo namin,,make sure lang na bago ikabit po ang valve spring eh lapat na lapat dapat sa valve seat yung mga engine valve ,,use grinding compound po na fine para maganda lapat ng valve,,
mga sir magpapakabit palang ako ng s4 evo nka mtrt na valve spring i need advice po sa pagkabit ng maayos
saka kong me settings pa po na babaguhin.
Paladin
s
Your trusted mechanic may change your tappet setting but. In our case the mechanic made 15-20 valve clearance or 10/15 with valve pocket.
Remember, go to a TRUSTED, SKILLED, EXPERIENCED MECHANIC as what is said by papa KR.
Paladin
13 front sprocket is too small IMO. Try 14T front sprocket. Rear sprocket depends on the mode you want on your bike. smaller for top speed or bigger for acceleration.
aklan
how bout my bigger sprocket what can you suggest? isn't OK if i use 14rear/ 36back my friend selling me 14rear/38 back what can you suggest i just have a stock rim right now.
Sonnyjha
mga master how bout MTRT vs CMS valve spring?? ano mas subok nyo na sa dalawa?? wla ksi me mganapan ng MTRT..
aklan
sir sabi ng nagbenta sakin mag valve pocket ng 2mm ok lang po ba?
paara daw d magbanggaan ung mga valve sa loob tama ba?
aklan
parang d ko na alam kong ano prblema sa spring ba or sa cams naka rcdi na ko humina pa ata ung speex
ko lAlo s4 evo cam mtrt vspring saka dualband na gamit ko nagpalit na din ako ng rim sa pinaliitan ko na tire ko
mas maganda pa nung nakastock ako mas may bilis ngaun kase power lang meron pero speed hangang 115 lng kaya itakbo
iaang beses lng ako nkapatakbo ng 125 nung me nakAsabayan akong motorstar na parang cbr.
tulong naman mga forumers.
