Mx King Tuneboss
mxking035
Update:
I bought CMS Cam T2 and CMS Valve spring.
Vspring not fitted in my stock valve, cam (stock or cms) can't rotate, mechanic said that I need a longer valve. So only installed is cms cam.
Any suggestion?
mxking035
Btw, we tried my cousins gold color raider with rim set+open pipe+smaller tire+rcdi "I feel the raider as just like an xrm", driver of my mxking said.
Very good acceleration and power at high rpm using cms cam t2 using tuneboss (map83)
JapSpeed
Update:
Any suggestion?
nge! imposible nman yn sir... same lng naman valves ng sniper 150 natin sa old models.. ng kaiba lng sa tappet screw. kng mas mahaba yng valves mg iba na yng lift ng cam mo. mas malaki chance mg untugan yng valves and piston. never heard longer valves anyway.
mxking035
Sir panu yun kahit stock cam ayaw umikot pag yung cms spring nakakabit, ano kaya solution don?
Pansin ko mas mahaba at mas malaki diameter ng cms kisa sa stock spring
mxking035
Update: Raider Reborn vs MxKing
800m (video at 400m)
Raider: BRT CDI, Namban Pipe, 30mm carb, stage 1 cam, spoke, thinner tire, one gasket remain, clutch spring, uma quick throttle, air box removed, below 50kg driver
MxKing: Tuneboss (Map83), hgm pipe, cam t2, plug coil (from multicab), others stock, below 50kg driver
Equal around 600m (raider has strong pickup every change gear but sniper has better acceleration at high rpm)
JapSpeed
mg uma body throttle 32 ka bro.. iwan na yn talaga.. lakas na ng mx king mo sir.. pa high comp kana para kahit stock yng body throttle iwan pa rin yng raider.. hehe.. congrats!!
mxking035
Sige sir, try ko rin mag K&N Air Filter, baka pumantay sa 400m.
Ok lang kaya mag clutch spring? Para kasing walang hatak pag change gear, mabilis lang mag accelerate
JapSpeed
/QUOTE]
okay na okay sir yng clutch springs.. not sure lng kng kasya yng png 135. gamit ko sa ngayon faito clutch springs. d ko pa na try kasi busy sa trabaho..[
Julio25
malamang dami na naman magre react na r150 user nyan sir...:D:D sa video nga ni sir japs eh dami mga nag react eh kitang kita naman ang resulta...touring mode lang si sir japs...:dance::dance:
mxking035
Haha, oo nga badtrip sya, andami binago matalo lang mxking, pero nung stock nilalaro lang nya c king, tapos nung naka ecu ako at brt narin sya ay sya na ang nilalaro, nag spoke pa, wala parin, tapos ayun pinagalaw na makina nya wala parin lalo na naka CMS cam si king,
Tinangal ko nga pala yung guma na cover ng airbox, banda sa upuan, yung maliit
