it's normal.. coming from small hole underneath. i noticed that when i use my stock pipe water with carbon deposit coming out from that hole. if i am using my open pipe no water...mga sir ano yung tubig na lumalabas sa tambutso ko yung sa ilalim na maliit na butas mxi150 user po ako
if you use other open exhaust,it usually cannot get this result,water from exhaust system,unless u have tune ecu it to be complete burning..got many other factor that make it cannot complete burning, such exhaust gaa flow,valve overlap n otherit's normal.. coming from small hole underneath. i noticed that when i use my stock pipe water with carbon deposit coming out from that hole. if i am using my open pipe no water...
I agree. It is completely normal. It happens to cars also. Observe new model cars in the morning. The spew out water on their exhaust pipes.mga sir ano yung tubig na lumalabas sa tambutso ko yung sa ilalim na maliit na butas mxi150 user po ako
