My Very Own Rear Disc Conversion (d.i.y.)
tom snipes
After almost 3years of waiting, one of my dream modification came true..
my wares:class a caliper kit
Heavy duty hub flange especially made for sniper..
stainless allen bolts
and RB pump bracket for stock brake pedal
This kit is practically a bolt on, no cutting on the caliper nor on the disc....
tom snipes
marking and drilling to the hub..holes should be on the rightmost portion...
applying rust converter to take care of the rust on the brake wall
100 % fit..
drilling holes on the rubber damper about 1cm. deep
tom snipes
cutting the spacer from the bracket, cut the whole thing..
attaching the hub flange to the mags... tighten the allen bolts in "X" pattern ..this is important in order to have a good alignment of the hub and to the disc...
bolt on the disc..
tighten bolts also in "X" pattern for good alignment...
tom snipes
Assembly time...check the allignment of the caliper.check how many washer should go in..
this is the most important part of the conversion,allignment of caliper to the disc, note that the rotor disc and the left brake pad should come in contact lightly with each other...
In this case ,I'll be using the stock spacer,1pc. flat washer.and the spacer which was previouslly cutted from the bracket,
using a scewdriver pry open to insert the bracket.. then tighten
attatch the stock bracket, use spacer...
assembling the pump master and the rb pump bracket
bleeding........pump the brake pedal until pressure builds up then hold, while holding , release the pressure from the caliper nozzle, do this several times until you the system is free from air bubbles ...
tom snipes
thanks lospeeder ; jangbest ; simplekhent ....
yves .. I used the hub flange especially manufactured for sniper...100% fit
with this type of flange there's no need to cut or grind the back portion of the single piston caliper because the flange is thick enough to ensure that there's clearance between the mags hub and the caliper...
Done.... now brake pads should undergo break in also.. maybe a couple of days before you could attain its full braking power...
jangbest
bro where did you buy the hub flange?? i badly need one :)
same Question bro????? Where did you get the Hub Flunge ????.....
Jonmitchell
is this what you called plugnplay bro? just drill the mags and ready to bolt? nice diy mods bro, we have the same model and color, and intact decals. hehe. Congrats...:thumbsup:
