Need A Lil' Help Here..
buko0
When i go full throttle while the mc is in neutral, the engine goes *blok-blok-blok* like it is choking or something then it dies. what could possibly be the problem here? only mods is open pipe and iridium spark plug. thanks for the responses. :D
prettyboy
Bro, same my experience before, you have to adjust the air and fuel mixture DIY...start mo yung motmot at ikutin mo yung air/fuel mixture nya at pakinggan mo ang andar nya! Baka napadami yung hangin na papasok keysa gasolina...or pwde dun mo ipa-adjust sa mech mo ilang segundo or minuto lang yan!
buko0
been trying hard as hell to adjust the a/f ratio. will do it again tomorrow. thanks for the inputs, sirs.
sniper71
paps,ifull close mo ung adjuster sa hangin clockwise,tpos ikutin mo ng 1 1/2 counter clockwise,paandarin mo motor,sa set-up n yn,dyan ka magsimulang itimpla sa gusto mong timpla,pcounter clockwise...
buko0
will try to do that later on. failed 2 times already. :p
francis
sir did you experience this problem after washing your sniper? if yes, maybe theres a water inside your carb, it accidentally get inside the carb.. just try to check it coz' i experienced this kind of problem just like you said it goes blok!blok!blok! then the engine dies...
buko0
nope sir, always experiencing this even if not after bike wash. :D
casmot
This happened to me before during high rpm the engine begins to sound like it has a limiter when in fact i am using rcdi, i learned that it was cause by my ignition wire. i put a cheap switch on it beneath my seat as a safety measure against bikenapper. i change to a high amp switch the problem was gone.
Stockbore
a sudden full throttle or slow full throttle?
