From the list you provided, it seems the damage to your bike is extensive. Good thing you're okay.
I would suggest checking the prices from your friendly, neighborhood 3S shop, then try to search for 2nd hand items other people have just lying around their house. This way you have an idea of how much said item is brand new and you can get better deals from those 2nd hand items. If you were to buy all those parts you listed brand new, it'll definitely cost you an arm, a leg and half your torso. As another alternative, you might want to consider having the damaged fairings repaired using fiberglass and painted to whatever color or theme you want. I know this will be cheaper. The sniper's telescopic fork is the same with fino/sporty if I'm not mistaken. If the TPOST is bent, try to ask your local machine shop if they can fix it, although it's still best to find an original, undamaged one. Repairing the TPOST will never bring it back to it's original condition. Disk Plate is the same with the Nouvo/Krypton Z so you might want to look this one up in sulit or maybe someone here has one. I've seen people selling their stock sniper mags too. Buying this from 3S is not an option. Believe me it's really EXPENSIVE, so much so that buying aftermarket mags is the best option. You might want to also consider aftermarket rims. The hardest part to look for in my opinion is the radiator. This might be the part that you would need to buy from 3S. I haven't seen anyone selling their stock radiator, since there are no aftermarket ones sold specifically for the sniper.
Hope this helps...Ride safe!!!
